control arm/camber question
Old Oct 6, 2003 | 08:20 PM
DeLiRiOu5's Avatar
Default control arm/camber question
a couple months ago i had the passenger upper control arm replaced. my alignment has always been relatively good with about a 2" drop, the tires always wore somewhat evenly with very minor inner wear. however, after i got the control arm replaced, it pulled REALLY bad to the driver side so i took it in to get an alignment. turns out that i was sold the wrong control arm, but i think it is too late to go back and exchange the part. what should i do? i can either go back and give the honda dismantling yard hell until they give me the correct control arm or purchase the spc camber kit or something and try and correcting the camber. the camber is so bad that in ONE month, my front driver tire was bald to the metal wire frame
edit: damnit, so i can't find the receipt... it's probably not possible to exchange the control now...?
Modified by DeLiRiOu5 at 9:30 PM 10/6/2003
Old Oct 7, 2003 | 05:04 AM
v4lu3s's Avatar
RTFM
depends on teh yards paolicy on returns/exchanges. I would call and ask them you may get lucky if not then go to a diff yard and get the right control arm.
crx_si-r
Jun 7, 2010 09:29 PM
ChevelleSSLS6
Mar 10, 2009 01:05 PM
Devo94ac
Sep 21, 2005 09:57 AM
down_the_hatch
10
Feb 17, 2005 06:40 AM
