Dc sports 4-1
Old Oct 6, 2003 | 04:23 PM
xkhalil333x's Avatar
Default Dc sports 4-1
was wondering your opinion on the usdm 4-1. seems much easier to do, but i dont see many dyno plots on it. i have a crazy deal on the jdm and usdm so im trying to decide which to get. any info is appreciated.
thanks
R
Old Oct 6, 2003 | 04:25 PM
SpeedRacer00-667's Avatar
Default Re: Dc sports 4-1 (xkhalil333x)
i love my DC JDM 2.5" header, except that it sits too low and hits everything.
Old Oct 6, 2003 | 04:28 PM
Default Re: Dc sports 4-1 (SpeedRacer00-667)
i dont think i will have a problem with ride height cause im keeping my itr stock height
Old Oct 6, 2003 | 04:32 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkhalil333x &raquo;</TD></TR><TR><TD CLASS="quote">seems much easier to do, but i dont see many dyno plots on it</TD></TR></TABLE>
If by easier you mean that you don't have to modify the cat., keep in mind that a good percentage of the gains from the DC JDM 4-1 are due to it being used with a high-flow cat. or test-pipe. I would recommend running a new cat. on either header, regardless of the collector size. I would venture to say that, on a mild motor, the gains for the USDM and JDM 4-1 would be similar if both headers were paired with high-flow cats or test-pipes.
Old Oct 6, 2003 | 04:36 PM
another reason, is that i have a 2 1/4 inch test pipe already that i was planning on using since it would bolt up to the usdm header and my stock piping
Old Oct 6, 2003 | 07:02 PM
Champ R's Avatar
Default Re: (xkhalil333x)
Dont bother with the USDM DC 4-1... unless your car is really low, you wont have much problems with the JDM model. Although im on stock height, the header doesnt really sit that low IMO as others say, and ive never scraped it over speedbumps etc... The JDM will also make more power and be better in the long run if you plan to further modify.
Old Oct 6, 2003 | 07:21 PM
Default Re: (Champ R)
OK, IF ANYONE WANTS A GOOD DEAL ON A JDM DC PM AND ILL LEAD YOU THE WAY
pchan
Sep 25, 2007 08:32 PM
p-p-porkchop
May 15, 2006 01:20 PM
.M.
Jul 28, 2004 07:32 AM
typeRSXS
Feb 8, 2004 10:07 PM
HX_Guy
Sep 4, 2001 09:56 AM
