explain mpfi swap?
up intil a couple weeks ago i owned an eg hatch, so im not really knowledgable in ef's. im looking for an ef hatch but dont know what my plans are gonna be yet. can someone explain to me what the mpfi swap is?
From: I told you to wait in the truck in Texas, United States
Changing from a throttle body to multi port fuel injection:
Check links posted here: https://honda-tech.com/zerothread?id=639552
Basically, it's converting a DX or LX model EF with dual point injection into multi-point injection by using a MPFI intake manfold, Si or HF model distributor, Si ecu, and an injector resistor. There are also some wiring changes to be made to the DPFI wiring harness. Try searching the archives, there is a ton of info in there.
90Attack
13
Oct 19, 2011 02:56 PM
