Piston rings or Valve seals
Old Oct 6, 2003 | 01:58 PM
aznxphreak's Avatar
Default Piston rings or Valve seals
No smoke comes out of the exhaust, but after a while, it looks like I get an oily film on the rear of my car. THere is however a lot of smoke coming out of my breather hole. So I thought my piston rings are gone. Also, my idle is getting more and more shakey and the pressure readings on my V-AFC are more erratic. Before I used to be consistant -515mm/Hg of pressure. Now it varies more erraticaly from -470-513mm/Hg. Anyone know what it could be. I always thought it was blow-by, but some people are giving me 2nd thoughts. Oh yeah, I'm running a turboed F23
Old Oct 6, 2003 | 02:55 PM
mmuller's Avatar
Mad Scientist
Default Re: Piston rings or Valve seals (aznxphreak)
doing a leakdown test would tell whats wrong
Old Oct 6, 2003 | 03:52 PM
aznxphreak's Avatar
But from what I said, what does the problem seem like.
Old Oct 6, 2003 | 04:01 PM
mmuller's Avatar
Mad Scientist
Default Re: (aznxphreak)
well as far as the rings go, it could be but since your vaccum readings are erratic and smoke comes out of the breather hole i would think has to with your valves seals.
Old Oct 7, 2003 | 09:08 AM
aznxphreak's Avatar
Default Re: (mmuller)
Hmmm... And it causes the engine to be shakey? Sometimes it stalls even. Even when the exhaust doesn't smoke, I get an oily film on the back. Didn't know that valve seals can degrade an engine that much. Strange thing is, my gas mileage isn't severely worsened. =T
Old Oct 7, 2003 | 06:53 PM
AzG35's Avatar
Erratic idle and stalling engine may be contributed to valve problems. A slighty bent or burnt valve can cause your idle to fluctuate hard and die at times. Just another thing to look into. A Leakdown test would show you were the problems lie.
Old Oct 7, 2003 | 08:52 PM
Mohudsolo's Avatar
Default Re: (AzSi22)
It could be the valve seals due to the pressure in both the intake and exhaust from the turbo, but I would bet on rings/cylinders. Has the block been sleeved? If not, I would suspect the cylinders are out of round and tapered. If you have ever had detonation problems, the Honda rings are very thin and not very tolerant of detonation which tends to damage the rings and the ring lands on the pistons.
A leakdown test would be a good start. Depending on what that shows, consider tearing down the bottom end to see what kind of shape it's in. Any chance it's a seal on the turbo?
Old Oct 7, 2003 | 10:05 PM
greebler's Avatar
Start with a cheap fix, replace the PCV valve. How many miles???
Old Oct 9, 2003 | 09:06 AM
aznxphreak's Avatar
Default Re: (greebler)
I don't think replacing the PCV valve would solve anything...
socialistic
18
Jul 1, 2011 04:31 PM
watisjdm
May 20, 2010 03:21 PM
oranginal
Jul 3, 2009 11:37 AM
Chuji
Aug 19, 2003 02:06 PM
