new springs
Old Aug 28, 2001 | 03:59 PM
bolognatits's Avatar
New User
Default new springs
Right now I have no clue what type of springs I have. My car rides really well but doesn't handle well. This is okay but I noticed that the right rear side is alot lower then the left and now that I put subs in the trunk that the back is lower then the front. Also I came to a tire shop to get a flat fix and noticed that the inside of my front is is horribly worn. Well to get to the point I was thinking about getting H&R sport springs how much do they lower a 1991 accord and where to get them I have seen ebay and opauto for $150. Does anyone have any Other suggestions for springs. And lastly how much should it cost to have installed?
Old Aug 28, 2001 | 05:40 PM
HoNdAeX11's Avatar
New User
Default Re: new springs (bolognatits)
Im wondering the same, thinking of lowering my car and wonder what kind of springs and struts are the best.
Old Aug 28, 2001 | 05:43 PM
haloseven's Avatar
Default Re: new springs (HoNdAeX11)
get some eibach prokits (1.25-1.50 drop, depending on struts), eibach also makes sportlines, which are a 2'' drop, which are terrible on normal roads...get the prokit, and some tokiko gas shocks/struts, or some kyb ajustables
Old Aug 28, 2001 | 06:52 PM
4doorH22's Avatar
Default Re: new springs (haloseven)
The major players in the spring business seem to be Eibach and H&R. I've had both and actually preffer the H&Rs, but everyone seems to say Eibach is the way to go. I've got the H&R Sports right now, about a 2" drop, but it's too low. At the auto-x my outside front tire (stock-sized no less) rub at the top of the wheel well. I'm getting taller springs and a height adjustment kit like Ground Control or something. Might even get coil-overs.
Old Aug 28, 2001 | 08:48 PM
smokin rubber's Avatar
Default Re: new springs (4doorH22)
for 300 I am looking at a set of ground control coil overs, Trying to figure out the spring rates. any ideas?
Old Aug 29, 2001 | 03:36 AM
urbanlegend21's Avatar
New User
Default Re: new springs (smokin rubber)
depends on what you want to do with the car.... i am getting custom coil overs with 400 front and 450 rear, of course I am taking my car out on the track. I wouldn't go lower than 300 in the front and 350 in the rear.
Old Aug 29, 2001 | 03:50 AM
HoNdAeX11's Avatar
New User
Default Re: new springs (urbanlegend21)
when you say 2" drop, do you mean 2 inches from the ground or 2 inches from where the car is now? And i have a speed bumb at my school that i have to go over everymorning so i have to think about that too.
Old Aug 29, 2001 | 04:15 AM
briq4's Avatar
THis may be a really dumb question but I'll ask anyhow.. When you drop a car does it have any adverse affect on the CV joints? I.E. are they designed to be opearting at "stock height" and when a car is dropped are they constantlly in an extended state or does it make no difference? Just curious.
Thanks!
Old Aug 29, 2001 | 06:32 AM
4doorH22's Avatar
2" drop = the car sits 2" lower than the stock ride height.
Shouldn't be any adverse effects on CV joints, but we who lower cars tend to drive the hell out of them so stuff wears out faster anyways. You should still get well over 100,000 miles out of your axels.
The suspension is designed so that the distance from tranny to wheel hub remains consistant throughout the suspension's travel, otherwise we'd all be poping CVs or binding on corners.
[Modified by 4doorH22, 10:34 AM 8/29/2001]
Old Aug 29, 2001 | 11:33 AM
street and auto-x for now, It might be a track car in a few years.
B_Swapped93
Jul 29, 2013 02:47 PM
AFAccord
Apr 30, 2011 08:04 PM
pbarb
Aug 25, 2006 10:26 AM
MBlake55
May 26, 2006 06:26 AM
alex01
Aug 23, 2004 12:53 PM
