my custom spark plugs, hehehe
Went to the track yesterday, here's the setup in a nut-shell.
D16Z6
JRSC@10psi
Hondata s200b w/ nitrous controls
crower rods
arias pistons 9:1
Car was originally tuned for 100 shot on pump gas. That put me in the 12's but it wasn't enough
. I switched it to C16 and upped the shot to a 120. Dropped me another 10th and gave me a few extra mph. This weekend I had a bright idea to try a 150 shot for the hell of it, doing a full rebuild this winter and going turbo. Anyway, we put a GSR fuel pressure regulator on the rail which bumped fuel from 42-49psi, truthfully I think my a/f was pretty good all day. Made 4 passes with no problems until I felt a miss in 4th gear. Pulled plugs and I had melted a ground strap off a plug. This was on the NGK V Power with a heat range of 9. I didn't have any 9's left so I put a BK7 in. Guess it was a little to much for that heat range because it blew the ground strap and porcelain right off the brand new plug. Once again this was halfway through 4th, the car didn't miss at all in and gears before that. Think it was excessive heat?
sorry about the horrible pic
Plug on the left is just the electrode. Plug on the right is one that I melted the ground strap off of.
Edit....
BTW, the last pass car shut down at 1,000ft and still went 13.0 at 96mph. I hit the brakes before the trap trying to catch the first turn off
Modified by GITWIDIT at 12:12 PM 10/6/2003
D16Z6
JRSC@10psi
crower rods
arias pistons 9:1
. I switched it to C16 and upped the shot to a 120. Dropped me another 10th and gave me a few extra mph. This weekend I had a bright idea to try a 150 shot for the hell of it, doing a full rebuild this winter and going turbo. Anyway, we put a GSR fuel pressure regulator on the rail which bumped fuel from 42-49psi, truthfully I think my a/f was pretty good all day. Made 4 passes with no problems until I felt a miss in 4th gear. Pulled plugs and I had melted a ground strap off a plug. This was on the NGK V Power with a heat range of 9. I didn't have any 9's left so I put a BK7 in. Guess it was a little to much for that heat range because it blew the ground strap and porcelain right off the brand new plug. Once again this was halfway through 4th, the car didn't miss at all in and gears before that. Think it was excessive heat?sorry about the horrible pic
Edit....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D3LSLO »</TD></TR><TR><TD CLASS="quote">update ur signiture</TD></TR></TABLE>
why? i don't have a npb et.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swift »</TD></TR><TR><TD CLASS="quote">when I look at that pic I feel like I need glasses. Any chance for a better one?</TD></TR></TABLE>
Sorry guys, I'll get a new pic up 2nite after work.
When i looked at it, it was like i had some glasses on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">what injectors?
RC 440's, where were you Mista?
Friday night on way to pick up a block from CRX Lee, the B&M FPR locked open bypassing all fuel back to the tank. I lost power for about 30 seconds, then everything was fine.
Now if that would have happen on Ewater on a nitrous pass, goodbye Z6!
Not to mention 3rd gear is gone and clutch won;t hold.
I decided to sit out. Hopefully be ready for next spring.
you can see how the electrode ground is partially missing in this pic. This is the NGK V Power 9 plug after 5 hard passes.
So I was out of NGK 9 plugs and I replaced it with this brand new BKR7E that made 1 pass. Once again, the miss was only about halfway through 4th gear both times and I got out of the throttle right away. I'm guessing it was due to excessive heat. What do you think?
damn craig, you my friend are a crazy bastard. Hey everyone, I know where there is a cheap D16 f/s
might smoke, drink coolant a lil bit
too much timming, remeber 4th gear is at the end of the run and your probably in that gear the longest and the motor is going to be at its hottest point. Id drop the timming down some.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx »</TD></TR><TR><TD CLASS="quote">too much timming, remeber 4th gear is at the end of the run and your probably in that gear the longest and the motor is going to be at its hottest point. Id drop the timming down some.</TD></TR></TABLE>
i am going to have to agree with that one
Thanks for the input guys, timing may be a problem but why did it go 4 passes and never miss a beat? Seems like if timing was off I would have felt it in the first or second pass.
The NGK 9 plugs made it several passes and without a problem, the BKR7E only made 1?
Not sure how much he took out, we tuned it conservative for the 100 shot and it screamed hard and loud for a long time. The car wanted more so I gave it to her without Tom's permission, hehehe.
I dont think its the timing,I think your 440s are past thier max w/ a 150hp shot.You said when you where using .052 (about a 90 shot) it put down 251whp/227tq and even then your Injector duty was around 90%..so with the 150hp shot your injector duty is WAY past 90%,not good..You could probably get away with 550s but if that was my set-up mixing juice with boost,I would run 720s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 »</TD></TR><TR><TD CLASS="quote">damn craig, you my friend are a crazy bastard. Hey everyone, I know where there is a cheap D16 f/s
No, Cody, you sir are the crazy bastard. H22 in the trunk of a del Sol. Makes me proud to be a sol owner.
</TD></TR></TABLE>No, Cody, you sir are the crazy bastard. H22 in the trunk of a del Sol. Makes me proud to be a sol owner.
lol, ya, but I wish I could make my 0wn spark plugs y0!
Actually the h22 thats in the front right now prolly has some nice custom pistons in cylinder #'s 2 and 4, now at 110psi, and 40psi on the compression test
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh6turbo »</TD></TR><TR><TD CLASS="quote">
No, Cody, you sir are the crazy bastard. H22 in the trunk of a del Sol. Makes me proud to be a sol owner.</TD></TR></TABLE>
HEY..how's that going by the way?? Dying to see the setup...Top Fuel seems to be the only company who have done successfully here...
