spoon ehaust??
Old Oct 6, 2003 | 06:40 AM
sicklexus1's Avatar
Default spoon ehaust??
I have my 01 ITR and have all basic boltons. Stage II cams, gears, fpr, vafc. I REALLY REALLY need an exhaust and I found a spoon exhaust, not sure if it is axle back or catback for 250 shipped. Is either of these worth it for my set up, or is it not worth it? Also how does it sound.
Either way I NEED to order one ASAP. Which one if not that one. I will need one with in a week.
Thanks So Much
Old Oct 6, 2003 | 06:43 AM
Ferrell's Avatar
Default Re: spoon ehaust?? (bonnieornelas)
$250... my guess is just the axleback.
You need to get rid of those bottlenecks.....
Old Oct 6, 2003 | 06:51 AM
Doctor CorteZ's Avatar
ditch the bottlenecks , ditch your OEM B pipe also.
actually , why not just get a real exhaust ?
Old Oct 6, 2003 | 07:20 AM
sicklexus1's Avatar
Default Re: spoon ehaust?? (Doctor CorteZ)
okay. So Which exhaust do I buy, that will help out the most.
Old Oct 6, 2003 | 07:22 AM
hungsteR's Avatar
Get a free-flowing exhaust without any bottlenecks. The ones that come to mind are SMSP, Hytech, and Fujitsubo.
Old Oct 6, 2003 | 07:25 AM
GokuSSJ4's Avatar
Default Re: spoon ehaust?? (hungsteR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungsteR &raquo;</TD></TR><TR><TD CLASS="quote">Get a free-flowing exhaust without any bottlenecks. The ones that come to mind are SMSP, Hytech, and Fujitsubo.</TD></TR></TABLE>
Those are some options and if you can not afford any of those or for something a bit lower in price you also have magnaflow ....
Old Oct 6, 2003 | 07:31 AM
hungsteR's Avatar
Default Re: spoon ehaust?? (Spoon1)
If cost is an issue then you could go a cheaper route. I think there is a member on the board by the name of K8Teller that does custom mandrel bend exhausts for about $250-$300. You can specify how many resonators and what kind of muffler you want him to use also.
Old Oct 6, 2003 | 08:08 AM
sicklexus1's Avatar
are the Fujitsubo and smsp direct bolt ons to my 2.5" testpipe. Or are they the same like the hytech, where you also need the header for it to work.
Where is the best place to buy either of these and prices?
Old Oct 6, 2003 | 08:13 AM
hungsteR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonnieornelas &raquo;</TD></TR><TR><TD CLASS="quote">are the Fujitsubo and smsp direct bolt ons to my 2.5" testpipe. Or are they the same like the hytech, where you also need the header for it to work.
Where is the best place to buy either of these and prices?</TD></TR></TABLE>
For the Fujitsubo, you need a JDM length cat. The SMSP should be a direct bolt on, I'm not sure about the Hytech.
Old Oct 6, 2003 | 08:14 AM
Chris N's Avatar
For the Fujitsubo, you need a JDM length cat. The SMSP should be a direct bolt on, I'm not sure about the Hytech.</TD></TR></TABLE>
Carsound makes a 12" high flow cat that works with the Fujitsubo, IPS Mike and SMSP have them. Flux and I have documented this repeatedly on H-T.
Old Oct 6, 2003 | 09:30 AM
AJ PwR's Avatar
Fuji is only 60mm , it doesnt match your pipe size (your cat) but it will bolt up without any problem.
Circuit Star-29
Oct 2, 2005 10:42 AM
2k1 SSM GSR
Feb 17, 2005 06:10 PM
Moonbus
Jun 25, 2003 02:13 PM
Skunk2Civic94
22
Apr 27, 2003 08:54 PM
redacura
Jan 3, 2003 05:14 PM
