need diagram to install my alram in my 94 civic coupe
well first, you need to state what alarm it is, and if you go to your local circuit city, they have tech sheets. tell them you need to make a copy real quick. you'll probably have to know somebody who installs there.
12volts white + steering column
Starter black/white + steering column
Second Starter
Ignition black/yellow + steering column
Second Ignition
Third Ignition
Accessory yellow + steering column
Second Accessory
Keysense
Power Lock green/white - 2pin plg blue-taped to
Power Unlock green/red - blue plg behind f-box
Lock Motor
Unlock Motor
Parking Lights+ red/black at fuse box or d.k.p
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. green/red - driver kick panel
Dome Supervision
Trunk/Hatch Pin grn/blk 2 sil.dot - blue conn. above fusbx
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue AC 2-pin conn. near dist.
Wait to start
Brake Wire green/white + at brake switch
Parking Brake
Horn Trigger blu/grn, blu/red - at steering column )
thats the exacat same thing circuit city will give you if they do do it for you.. most the time they arent supposed to cause i would not do it for a customer unless he was cool or i knew him, but ill hook honda-tech up...
Second Starter
Second Ignition
Third Ignition
Second Accessory
Keysense
Lock Motor
Unlock Motor
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Dome Supervision
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Wait to start
Parking Brake
DB1_559
Jan 27, 2006 02:29 PM
thanks guys
