D16A6 Help Tip
Old Oct 5, 2003 | 06:37 PM
90Sicvic's Avatar
Default D16A6 Help Tip
Maybe a little help for the D16A6 fans. About a year ago I was gonna do a DualCam ZC swap in my 4G hatch. I had went to the junkyard and grabbed the DualCam ECU I needed. So I never did the swap had the ECU laying around decided to try it on my D16A6, well low and behold no check engine lights, higher revs and no speed limitor that I can find. The car eats fuel like a pig but it runs very strong and never misses a beat. The timing maps and fuel curves are alot more aggressive than the stock ECU. You will notice that the cases are different and the location you pull it from is also different. Sample task, change the cases, bolts in stock location then. Cant see you code ligt but if you have a clue on what to do you shouldnt have lights
Just to let all know....discuss
thaiphob
25
Nov 6, 2015 11:33 PM
thompbird
Jul 3, 2007 05:16 PM
newb23
Sep 15, 2003 05:26 AM
4thgencivicsi
Jul 1, 2003 03:19 PM
blackEF
Oct 19, 2002 12:46 PM
