H22a in g2 teg
Old Oct 5, 2003 | 06:23 PM
Hawkeye's Avatar
Default H22a in g2 teg
How hard do you guys think it would be to put an h22a in a 91 teg. I want to do an engine swap. but im not sure what engine.
Old Oct 5, 2003 | 06:29 PM
VTECorona's Avatar
Default Re: H22a in g2 teg (Hawkeye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkeye &raquo;</TD></TR><TR><TD CLASS="quote">How hard do you guys think it would be to put an h22a in a 91 teg. I want to do an engine swap. but im not sure what engine.</TD></TR></TABLE>
Try a search. For you, the easiest swap would be any b-series motor. h22's can be put into an integra chassis but it is harder to do.
Old Oct 5, 2003 | 06:56 PM
patdemps's Avatar
Default Re: H22a in g2 teg (VTECorona)
this topic has been covered. just search.
i would stick with a b series motor.
Old Oct 5, 2003 | 08:26 PM
Newman's Avatar
New User
Engine bay is much smaller in the DA/EF chassis than in the EG/DC chassis. Therefore, you need to do some cutting to the framerail for the transmission clearance and welding on the passenger side for a new mount & bracket. Not very common since it's easier (and now getting common) in the DC chassis, so nobody is making a kit for it.
Old Oct 6, 2003 | 10:19 AM
EV1L SI's Avatar
SCAM ARTIST
Default Re: H22a in g2 teg (Newman)
Go to http://www.g2ic.com and use their search function. There is a member there running a turbo H22 in his 2nd Gen Integra. Very impressive setup. Check it out.
acintegragsr
Oct 16, 2004 04:54 PM
ricehero
Mar 23, 2004 10:26 PM
EP3CivGrl
Sep 22, 2003 09:20 PM
..::91TEG-G2::..
Jul 4, 2003 06:58 PM
psychopath211
Apr 26, 2003 07:48 AM
