Del Sol to EG front end conversion (What does it take)
Old Oct 5, 2003 | 01:04 PM
EG2 SiR's Avatar
Default Del Sol to EG front end conversion (What does it take)
Like that title says, does anyone know exactly what it takes to do this? Besides the obvious; hood, fenders, headlights, corners, bumper and possibly core support.
Old Oct 5, 2003 | 01:12 PM
Tad's Avatar
Tad
just from the looks of it, it'll definetely take some bodywork/shaping,
look at the fenders, sols dont have the headlights shaped in perfectly like that, and eg civics dont have the shape of the door mixing in with the fender like that.
Old Oct 5, 2003 | 01:18 PM
EG2 SiR's Avatar
Default Re: (Tad)
yeah, you would probably have to cut and weld the front of an EG fender and the back of a del sol fender.
Old Oct 5, 2003 | 01:19 PM
egturbo's Avatar
Default Re: Del Sol to EG front end conversion (EG2 SiR)
i love it. best of both worlds.. do it if u havent
Old Oct 5, 2003 | 02:24 PM
jdmsiR20's Avatar
Default Re: Del Sol to EG front end conversion (egturbo)
wow it actually looks pretty good... now u just gotta add the automatic moonroof assembly
Old Oct 5, 2003 | 02:28 PM
.::miLan's Avatar
Looks like a custom job as other have noted. You will probably need the Del Sol 1/4 panels, and the EG 1/4 panels, cut them in two, and weld together, then sand, fill, prime, and paint.
Old Oct 5, 2003 | 02:29 PM
EG2 SiR's Avatar
Default Re: Del Sol to EG front end conversion (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">wow it actually looks pretty good... now u just gotta add the automatic moonroof assembly </TD></TR></TABLE>
mmmmmm . . . . trans-top.... I would just buy/import a real EG2 for that if I had the cash.
Old Oct 5, 2003 | 02:39 PM
Ricey McRicerton's Avatar
Looks pretty damn cool!! Id say go for it, but I would imagine that it takes quite a bit of bodywork! Best of luck and post up here when you get it done!!
Old Oct 5, 2003 | 03:50 PM
CunninLynguist's Avatar
Default Re: Del Sol to EG front end conversion (Ricey McRicerton)
One of the best conversions.
Doesnt look bad at ALL.
Old Oct 5, 2003 | 03:56 PM
ek9mugen's Avatar
Default Re: Del Sol to EG front end conversion (Scot project)
that is the sencond sol i have seen with the conversion
it looks bad ***
Old Oct 5, 2003 | 03:57 PM
BLK JDM's Avatar
I know a lot of Del Sol people put the EK front end on their Sol. A friend of mine has it and all the did supposedly was EK hood, fenders, bumper, bumper support, lights, and core support.
Old Oct 5, 2003 | 04:10 PM
WangChung's Avatar
Default Re: Del Sol to EG front end conversion (jigga008_99)
good craftsmanship, but that looks aweful . . .
Old Oct 5, 2003 | 04:18 PM
ThisLittleSleepeR's Avatar
Default Re: Del Sol to EG front end conversion (97civhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civhatch &raquo;</TD></TR><TR><TD CLASS="quote">good craftsmanship, but that looks aweful . . . </TD></TR></TABLE>
i have to disagree, that thing looks good to me
Old Oct 5, 2003 | 04:22 PM
Dougie Pants's Avatar
Default Re: Del Sol to EG front end conversion (ThisLittleSleepeR)
I think it looks pretty good. I'm for sure that it is not a direct swap out of anything. None of the front end parts are the same between the two of them.
Old Oct 5, 2003 | 04:27 PM
User 5426's Avatar
Default Re: Del Sol to EG front end conversion (Dougie Pants)
Damn, it looks better on that car than it looks on mine.
Old Oct 5, 2003 | 04:29 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: Del Sol to EG front end conversion (SeaQuake)
that looks damn good. like they said, you would prolly just have to custom weld the sol and eg fenders together.. everything else should be self-explanitory..
Old Oct 5, 2003 | 04:53 PM
chrisir19's Avatar
Default Re: Del Sol to EG front end conversion (Hatchy-Ownzjo0)
YEAP... weld the sol fender to the civic fender even;y above the wheel. everythign else should bolt up. maybe a rad. support swtich but.. that hit is hot!
yeah get the auto roof = P I M P
seen the video for the 1st time today... didn't know they had auto sunroof overseas
Old Oct 5, 2003 | 05:00 PM
single cam vtecn's Avatar
Default Re: Del Sol to EG front end conversion (chrisir19)
i have redone the front end of my civic before and i can tell u just about everything u need to do this. u will need the civic fenders, hood, lights, bumper, and radiator support for it to fit right. alot of bondo!! and a really steady hand to cut the two fenders and match them to the civics. like a post before u will cut and weld the fenders from both cars. u will also need to paint the engine bay unless u wanna have a car thats got welding marks all in it. well i hope that helps.
Old Oct 5, 2003 | 05:07 PM
N1NjA TuRtLE's Avatar
Default Re: Del Sol to EG front end conversion (single cam vtecn)
imo you should do a Del sol to 99-00 Si Front end, I seen that **** around my neighborhood looks fawkin clean. With the Si lip and everything, trust me it looks good.
Old Oct 5, 2003 | 05:11 PM
EG2 SiR's Avatar
Default Re: Del Sol to EG front end conversion (YellowSpoonEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowSpoonEG6 &raquo;</TD></TR><TR><TD CLASS="quote">imo you should do a Del sol to 99-00 Si Front end, I seen that **** around my neighborhood looks fawkin clean. With the Si lip and everything, trust me it looks good.</TD></TR></TABLE>
IMO the headlights are TOO big for it.
Old Oct 5, 2003 | 05:18 PM
[Caster]'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThisLittleSleepeR &raquo;</TD></TR><TR><TD CLASS="quote">
i have to disagree, that thing looks good to me</TD></TR></TABLE>
looks surprisingly nice!
Old Oct 5, 2003 | 05:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR &raquo;</TD></TR><TR><TD CLASS="quote">
IMO the headlights are TOO big for it.</TD></TR></TABLE>
no trust me dude, they look perfect on a del sol, cuz the del sol lights have sorta the same shape as the 00 civic headlights, if i had a pic or knew how to photoshop it i would do it for ya,but idon't know how and i don't got a pic
Old Oct 5, 2003 | 05:34 PM
EG2 SiR's Avatar
I really don't like it
Modified by EG2 SiR at 6:59 PM 10/5/2003
Old Oct 5, 2003 | 05:57 PM
User 5426's Avatar
The 92-95 looks better. the 96 looks ugly to me.
Modified by SeaQuake at 7:46 PM 10/5/2003
Old Oct 5, 2003 | 06:12 PM
flat-blk-HB's Avatar
the 92-95 front end looks pretty good..
