Need a little help with adjusting clutch cable!
Old Oct 5, 2003 | 11:17 AM
TwztdSi's Avatar
Default Need a little help with adjusting clutch cable!
My clutch isn't engaging until the pedal is almost all the way out. Can adjusting the clutch cable help this? If so do I need to tighten it or or loosen it? As always any help is a appreciated. Thanks
Old Oct 5, 2003 | 11:25 AM
AbaZ's Avatar
Default Re: Need a little help with adjusting clutch cable! (TwztdSi)
Sounds like the clutch could be out of adjustment, under the battery you will see the clutch cable. (plastic) with a threaded little nut on it. pull up on the cable to see how much slack is in it. You should want to thread it by hand to the point where they is no more play on the lower side. It is also possible your clutch needs to be replaced.
Old Oct 5, 2003 | 11:30 AM
TwztdSi's Avatar
The clutch is pretty much brand new. Replaced when I did the ZC swap. Has less than 300 miles on it.
Old Oct 5, 2003 | 11:53 AM
hugh_jazz_sponer's Avatar
Default Re: (TwztdSi)
mine does this too. curious if it can be adjusted as well.............
bmxtrev
Transmission & Drivetrain
May 20, 2011 08:10 PM
zeroairskter
Feb 3, 2011 09:03 PM
Beeracer930
Apr 25, 2010 09:51 PM
almostjdmeg
Oct 7, 2008 11:46 AM
808EG6B18C1NA
May 5, 2006 02:47 PM
