Anyone know what this is?
Old Oct 5, 2003 | 10:40 AM
Acura_I-RS's Avatar
Default Anyone know what this is?
when looking at the engine bay there is a sensor/device on the upper right corner of the intake manifold and it has 2 vacuum ports and a cap on it that you can acually remove and put back on. Anyone know what this is??
Old Oct 5, 2003 | 10:47 AM
Acura_I-RS's Avatar
Default Re: Anyone know what this is? (Acura_I-RS)
its just a little black round cap that goes on the top of it, im just trying to identify, because i cant find it in my manual
Old Oct 5, 2003 | 12:11 PM
Greg123's Avatar
good question....anyone?
Old Oct 5, 2003 | 12:35 PM
threatcon13's Avatar
New User
Probably the IAT(intake air temperature) sensor
Old Oct 5, 2003 | 02:34 PM
Greg123's Avatar
Default Re: Anyone know what this is? (Threatcon13)
uhh, bump for some real info!!!
Old Oct 5, 2003 | 02:36 PM
mmuller's Avatar
Mad Scientist
Default Re: Anyone know what this is? (Greg123)
evap solenoid
Old Oct 5, 2003 | 02:51 PM
patdemps's Avatar
Default Re: Anyone know what this is? (mmuller)
take a picture of it. then post it up. then for sure we'll give you an answer. its not real clear what your exactly talking about.
Old Oct 5, 2003 | 03:10 PM
Acura_I-RS's Avatar
Default Re: Anyone know what this is? (patdemps)
i dont know where my camera is, if anyone has an up close pic of an ls motor, i could point it out easy!!
there is a little black **** on top of it, the **** comes off like its plugging a vacuum source or something not needed..
its right in the corner of the ls intake manifold, with that little black cap pointing straight up
Old Oct 5, 2003 | 03:30 PM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">evap solenoid</TD></TR></TABLE>
my vote
chris
Old Oct 5, 2003 | 03:52 PM
Servo's Avatar
Bad pic, I know. The evap solenoid is the black thing sticking up right in the middle of the IM. I don't have anything like you described on the right corner of the manifold. Mine is OBDII spec, so maybe that makes a difference.
Old Oct 5, 2003 | 04:18 PM
GreensleeperB16's Avatar
Its you evaporative purge solenoid
Old Oct 5, 2003 | 04:19 PM
Acura_I-RS's Avatar
Default Re: Anyone know what this is? (ReX)
well, it kinda helps, look right at the brake fluid canister, then look right across to the intake manifold, its right on that corner(
OBD1 also, sorry i didnt say earlier!!!
Old Oct 5, 2003 | 04:27 PM
Servo's Avatar
I just went out and looked at that little nub sticking out on that corner of the IM. It's just a piece of the IM cast iron or whatever it's made out of. Looks like something could mount there, but it's not anything on my car. I guess the OBDI is different.
Old Oct 5, 2003 | 05:05 PM
Acura_I-RS's Avatar
yea, there is a sensor there on my car,a nd im wondering if thats whats making it idle a little weird after running for a while
Old Oct 5, 2003 | 07:41 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You're referring to #18, which the website only lists as "valve assembly" and the little cap #16 is listed as the filter for that valve assembly. I would have to check my helm's to see what it is but I don't have it w/ me.
Old Oct 6, 2003 | 03:10 PM
Acura_I-RS's Avatar
Default Re: Anyone know what this is? (PatrickGSR94)
yea, number 18 in that pic, i couldnt find out what the hell it is or what it does at all
killacam661
May 1, 2007 10:06 AM
soulrider4ever
Mar 8, 2007 03:47 PM
v-tec maz
12
Apr 4, 2006 02:49 PM
Lewdin' Incognito
Sep 2, 2005 03:44 AM
