mpfi swap....won't start
I have a 91 civic dx and i am using a PG7 ecu (88-89 integra), 89 si manifold, 89 si dizzy. I sounds like it's getting no spark. I re-checked all the wiring and tried switching the two wires around and it still wont start. I changed the ignitor and coil from my dx and it's the same thing. Where did I go wrong? Any suggestions would be greatly appreciated. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xvracing »</TD></TR><TR><TD CLASS="quote">I sounds like it's getting no spark.</TD></TR></TABLE>
It sounds like it's not getting spark, or it's not getting spark?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blcwsfly20 »</TD></TR><TR><TD CLASS="quote">get a 92-96 4 door civic ex ecu</TD></TR></TABLE>
That won't work either. Thats OBD1, he'll need a dizzy and the coversion harness for OBD1.
Some people shouldn't give info unless they know 100% for sure.
see if its getting spark. take out aspark plug, put the wire on it. but the plug threads against something metal to ground it, then have soemoen try and start it. if you see the spark plug arcing then you got spark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xvracing »</TD></TR><TR><TD CLASS="quote">Edit: I switched the white wires</TD></TR></TABLE>
I'm assuming by this he did get it running....
it's not getting spark for sure...but I just checked the date on the ecu and it says 86. I think i bought a 86-87 ecu instead of an 88-89 ecu. I will try to get a different ecu and see if it starts. If anyone has a 88-89 pg7 auto ecu for sale please let me know.
waz up xvracing i have the same problem . my friend and I was doing the same setup with the rex. just to let you all know bottom end d15b2 head 91si with 2port injector it was working fine. until we swap it to mpfi now it won't start. we got everything plug up right we got resestor box for mpfi. we have fuel running from rails we got spark from plugs. but it won't start. we need help.
91_civic_lx
Apr 8, 2017 07:57 PM
greatxpectations
Jan 22, 2006 09:31 PM
