head builders or head shops!!
Old Oct 5, 2003 | 01:35 AM
theslugbug's Avatar
Default head builders or head shops!!
i need a head for my b16 stock block. i want to maybe run 12s. what kind of head mods should i do, going to spend around 1500. jun3 skunk toda?? 1500 is including cams, vavletrain, cams gears and port ect.. what setup can i get that will be the best. if u have experience with let me know ALL DIFFERENTS SETUP THERE ARE OUT THERE WITH FAST B16 SETUP combinationS and what i will be expecting from THESE setups. what can i expect from jun 3 cams, type r vavletrain, type r cam gears and thats it with a stock b16 bottomend? HHHHEEEEEELLLLLLPPPPP
Old Oct 5, 2003 | 02:25 AM
Broken Gearbox's Avatar
Default Re: head builders or head shops!! (alllgo)
https://honda-tech.com/zerothread?id=629029&page=1
Old Oct 5, 2003 | 10:29 AM
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alllgo &raquo;</TD></TR><TR><TD CLASS="quote">i need a head for my b16 stock block. i want to maybe run 12s. what kind of head mods should i do, going to spend around 1500. jun3 skunk toda?? 1500 is including cams, vavletrain, cams gears and port ect.. what setup can i get that will be the best. if u have experience with let me know ALL DIFFERENTS SETUP THERE ARE OUT THERE WITH FAST B16 SETUP combinationS and what i will be expecting from THESE setups. what can i expect from jun 3 cams, type r vavletrain, type r cam gears and thats it with a stock b16 bottomend? HHHHEEEEEELLLLLLPPPPP</TD></TR></TABLE>
with a stock block 12's will be hard what kind of car?
Old Oct 5, 2003 | 10:39 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: head builders or head shops!! (MAX_CFM)
With slicks all motor with a built head you can look foward to times no lower than a 13.5 IMO.
Best up that compression.
Good luck bro
Old Oct 5, 2003 | 06:51 PM
theslugbug's Avatar
Default Re: head builders or head shops!! jun3 (alllgo)
some people told me that with jun3 cams and vavletrain and port will make it hit 12.5, i guess they were revving up to 12000rpm plus... i want to rev up to 10000 with jun3 cams. anyone have really experience with these cams with a stock b16 bottom??
OR is there any shops anyone knows that sell fully built head for good price around southern cali.
SR20S13
Feb 23, 2010 06:27 PM
IGotVTECyo
Dec 17, 2006 10:51 PM
ekay. jay
Oct 9, 2006 08:46 AM
crazySiR
Mar 15, 2006 07:20 PM
