Best Coilover Suspension For Drag Racing?
Old Oct 5, 2003 | 12:05 AM
slowcivic's Avatar
New User
Default Best Coilover Suspension For Drag Racing?
That will fit a 92 Civic hatch. Please post your openions. Thanks.
Old Oct 5, 2003 | 02:19 AM
Dual Cams's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (slowcivic)
I have to go with APEX N1
Old Oct 5, 2003 | 04:26 AM
D-Man's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (Dual Cams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cams &raquo;</TD></TR><TR><TD CLASS="quote">I have to go with APEX N1</TD></TR></TABLE>
N1s are an excellent for road racing but if you want the best for drag racing go with a Penske set-up.
Old Oct 5, 2003 | 05:32 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: Best Coilover Suspension For Drag Racing? (D-Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man &raquo;</TD></TR><TR><TD CLASS="quote">
N1s are an excellent for road racing but if you want the best for drag racing go with a Penske set-up.</TD></TR></TABLE>
Good answer, but OMG who has $4000 to buy these?
Clayton
Old Oct 5, 2003 | 10:21 AM
D-Man's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (Clayton)
yeah,kinda fantasy a more realistic choice would be koni yellows or tokico 5-ways with some kind of slip-on coil-over like the skunk2 or ground-controls.
Modified by D-Man at 10:21 AM 10/25/2003
Old Oct 5, 2003 | 12:31 PM
slowcivic's Avatar
New User
I'm Just Looking To Buy Coilovers for the Rear of a 92 Civic hatch . Something that will allow me a good deal of Stiffness Adjustability and Ride Height adjustment.
Old Oct 5, 2003 | 12:48 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man &raquo;</TD></TR><TR><TD CLASS="quote">yeah,kinda fantasy a more realistic choice would be koni yellows or tokico 5-ways with some kind of slip-on coil-over like the skunk2 or ground-controls.</TD></TR></TABLE>
Old Oct 5, 2003 | 08:34 PM
gritsak's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (Boostfed)
the JG full coilovers are made for drag racing i believe...they are self dampening adjustable and the coilovers are "upside down"...prolly a term for it but i dont know what its called
Old Oct 5, 2003 | 08:39 PM
SOUNDEFFECTS's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (gritsak)
Take the N1's, throw on some 16k rear springs...(900lb)
Old Oct 19, 2003 | 04:23 PM
J2turbo21's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (SOUNDEFFECTS)
A buddy of mine has some KYB AGX for $250 (used) that im thinking about getting.Also use some 900lbs springs for the rear,its an all motor setup but not daily driven.
Old Oct 19, 2003 | 05:56 PM
sohc_vtec 2NR's Avatar
are the tein basic damper anygood for drag racing?
Old Oct 19, 2003 | 06:19 PM
Jared's Avatar
Default Re: (sohc_vtec 2NR)
I'm running the 18kg/mm skunk2s in the back of mine right now, picked up the 60's quite a bit, but very harsh. What are you guys running in the front? I have two sets of springs here, one 400lb, the other is 600lb.
Old Oct 19, 2003 | 07:14 PM
J2turbo21's Avatar
Default Re: (Jared)
18kg's are like 1000lbs?
Old Oct 19, 2003 | 07:15 PM
Jared's Avatar
Default Re: (J2turbo21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">18kg's are like 1000lbs?</TD></TR></TABLE>
yup
Old Oct 19, 2003 | 07:20 PM
J2turbo21's Avatar
Default Re: (Jared)
Thats what i plan on getting also.They're cheap but shipping is a bitch.
Old Oct 20, 2003 | 08:00 AM
T4eg's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (jerseykid609)
Not a Coilover but I've got koni yellows with drag launch spring. (Best of 1.67 60ft 91 crx si with ls/vtec)
And also got the B+G roadrace 12-way adjustable...thinking about running that on the race car (92 cx)
Old Oct 23, 2003 | 06:21 PM
hybridnorth's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (BlueHatch00)
call the guys up at KW Suspension or go to their site
they set me up with a wicked set for my 93 eg
height, bump, and rebound adjustable
Old Oct 23, 2003 | 06:30 PM
myke's Avatar
From: South LA...107th and fig to be exact...for the foo
Default Re: Best Coilover Suspension For Drag Racing? (hybridnorth)
Advance Design drag shock...thats all u need and they are rebuildable
Old Oct 23, 2003 | 08:57 PM
FULLTHROTTLE's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (1797ccs)
Im using Tokico 5-ways with GC coiovers, 380lb fronts, 1000lb rears.
Hitting solid 1.9s, and the occasional high 1.8 with only 217 hp. and on drag radials. Note: this setup will kill you on the street though. way too rough and hard to control over bumps and in turns.
Old Oct 24, 2003 | 05:32 AM
sihatch19's Avatar
konis are awsome
Old Oct 24, 2003 | 06:26 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1797ccs &raquo;</TD></TR><TR><TD CLASS="quote">Advance Design drag shock...thats all u need and they are rebuildable</TD></TR></TABLE>
very nice set of shocks indeed
Old Oct 24, 2003 | 10:12 AM
sircrxracer's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (2.2Lcivic)
More info on the Advance Design drag shocks??? Web Addy? Thanks Rob
Old Oct 24, 2003 | 12:12 PM
DaveF's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (sircrxracer)
http://www.ground-control.com/
here is the advance design site.(they do have honda applications.)
http://www.advance-design.com
Modified by 2.2Lcivic at 4:26 PM 10/24/2003
Modified by 2.2Lcivic at 4:27 PM 10/24/2003
Old Oct 24, 2003 | 06:35 PM
SEFIxCivic's Avatar
i hear advanced design wear out quickly and need frequent rebuilds.
Old Oct 25, 2003 | 02:41 AM
slrh22hatch's Avatar
Default Re: Best Coilover Suspension For Drag Racing? (SEFI8LOxCivic)
My friend had agx adjustables with ground controls 400lb in front and 1050lb in the rears running 1.6 60ft in his civic hatch and put on some ground control advance designs and the 60ft stayed the same. Not worth the money to me for the advance designs.
