jdm sir cluster wiring into 91 hatch
Old Oct 4, 2003 | 11:03 PM
hatchback SI's Avatar
Default jdm sir cluster wiring into 91 hatch
Can anyone help with the wiring for a Jdm SIR cluster into my 91 civic hatch Si. Pictures will help out alot. Also I have a speed sensor with a black, yellow, and yellow/white wire coming out of it. To what wires on the jdm cluster do these connect to. I have been looking everywhere for wiring directions that someone else has done but cant find any. Please help...ASAP....Thanks
Old Oct 5, 2003 | 09:20 PM
Default Re: jdm sir cluster wiring into 91 hatch (hatchback SI)
I have looked all over this website and others and i am either getting links to pages that no longer exist or use-less information like telling me what wires do what. how am i supposed to know what my own wires do. alls i need is someone that has wired it up to take a picture of the cluster disconnected and the wires they wired the new harness's to. andy help is appreciated.
thanks
Old Oct 6, 2003 | 08:43 AM
EF_LSVtec's Avatar
here's a site for you... http://www.geocities.com/Motor....html
about the VSS, connect the black wire to any good ground, yellow to your vss line (cluster B-1), yellow/white to a switched power.
Old Oct 6, 2003 | 10:45 AM
Default Re: jdm sir cluster wiring into 91 hatch (EF_LSVtec)
alls that page does is tell me what the jdm wires do. how do i ind out what my own wires do. i have three plugs on my car not two like the web site says. my car is a 91 civic si. i have a 2 wire blue plug, a 7 wire grey plug and a 12 wire grey plug. so i would need a site showing the cluster wires actually butt connected to a usdm harness or a picture so i can match there wires to mine.
Old Oct 6, 2003 | 01:00 PM
EF_LSVtec's Avatar
OK, now here's a site that tells you what your 91 hatch wires do... http://www.cynoptics.com/tldrivers/800.htm , scroll down all the way to the bottom to find the instructions. I hope this helps in anyway. All I did was search on MSN and type 91 Civic Cluster diagram. I'm sure you could have done it too.
btw, click on tech article and just follow the prompt...
Old Oct 6, 2003 | 01:13 PM
Snowboarding EF's Avatar
bump for good info.. i needed it
Old Mar 28, 2009 | 10:51 AM
crxnatic's Avatar
i know man those diagrams does not help they should show you what color wires from the usdm goes on the jdm color wire like red/blue goes on red/white. if you guyss have something like that. it will be a lot easier. thanks
mr.krits
Aug 15, 2007 05:53 PM
ballermc5
14
Oct 28, 2006 03:52 PM
$racer1
Aug 2, 2006 03:28 PM
BraydenR
Aug 23, 2005 08:56 AM
spettinger
May 11, 2003 08:16 PM
