Just bought a 92 DX Hatch.. Motor wont start...
Old Oct 4, 2003 | 10:02 PM
mkiv_tt's Avatar
Default Just bought a 92 DX Hatch.. Motor wont start...
Ok I just got a 92 Hatch at an auction.. The starter cranks over, but the car is not starting... I did a compression check and its bad.. 1st 155 2nd 140 3rd 80 4th 135. Im pretty sure the engine is fucked.. My question is would the engine start with that kind of compression? Or does it have some ignition problems? What do those engines run used, or at a junkyard?.. Its the SOHC non vtech
Thanks for any help
Old Oct 4, 2003 | 10:03 PM
Tad's Avatar
Tad
how much u pay?
Old Oct 4, 2003 | 10:05 PM
blackhatchy's Avatar
Default Re: Just bought a 92 DX Hatch.. Motor wont start... (mkiv_tt)
to answer your engine question, you can find prices at http://car-part.com.
oh yeah, its VTEC, not VTECH
Old Oct 4, 2003 | 10:11 PM
Tad's Avatar
Tad
Default Re: Just bought a 92 DX Hatch.. Motor wont start... (blackhatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy &raquo;</TD></TR><TR><TD CLASS="quote">
oh yeah, its VTEC, not VTECH </TD></TR></TABLE>
werd
Old Oct 4, 2003 | 10:42 PM
aw1234dude's Avatar
Default Re: Just bought a 92 DX Hatch.. Motor wont start... (Tad)
Start with the basics, check for spark at the spark plugs, if fuel is getting to the injectors, if the injectors are squirting, and if any of the fuses are blown.
Old Oct 4, 2003 | 11:07 PM
2lua's Avatar
you could have leaky valve or worn piston rings. try to recheck your compression again to be sure. you might have a blown head gasket only if you have the compression with 2 cylinder next to each other.
Old Oct 4, 2003 | 11:08 PM
2lua's Avatar
you could have leaky valve or worn piston rings. try to recheck your compression again to be sure. you might have a blown head gasket only if you have the compression with 2 cylinder next to each other. did you check for spark, wires, plugs...ect
Old Oct 5, 2003 | 04:59 AM
mkiv_tt's Avatar
Default Re: Just bought a 92 DX Hatch.. Motor wont start... (2lua)
I put new plugs in.. The valve cover is leaking pretty bad into the sparkplug well so that dosent help.. I put new ones and it still wont start up. Im going to check the distributer next.
Will the car still start with that kind of compression?
I got the car for 850 taxes towing it will be like 1000.. red perfect interior, 150k miles. Ive yet to clean the ouside so hopfully it turns out well.
Old Oct 5, 2003 | 05:51 AM
Plan B's Avatar
that compression isn't all that awful for one of those, i thought.
Old Oct 5, 2003 | 02:46 PM
zer0.'s Avatar
sounds like you got a good deal,now you have an excuse for a swap!!!
Old Oct 6, 2003 | 02:43 PM
mkiv_tt's Avatar
I checked the distributor and its brand new! The rotor on it is perfect and the distributor cover is new also.
Would the car start with a Blown Head Gasket?
Old Oct 6, 2003 | 02:45 PM
Archidictus's Avatar
Unceasing Measure
A.) depends on how bad it is and
B.) order that B18C5 swap right now so you don't have to worry about the busted-*** engine that's in it.
Old Oct 6, 2003 | 03:29 PM
mkiv_tt's Avatar
Default Re: Just bought a 92 DX Hatch.. Motor wont start... (Archidictus)
I dont think im going to keep the car.. I just want to get it running to sell.. I know its still worht a lot not running, but id like to try to figure it out..
Any ideas?
k3nnex
Dec 16, 2010 04:04 PM
NipponRacing
33
Apr 12, 2007 04:35 PM
crnimacak
Feb 6, 2006 04:57 AM
