Dropped Redline AND Code 31?WTF?I'm confused...
Old Oct 4, 2003 | 08:51 PM
slvrcivic97's Avatar
Default Dropped Redline AND Code 31?WTF?I'm confused...
Yes, this is posted in TECH too but I visit this more often and there's no one in tech right now and I kinda want to get an idea of what's wrong here...Thanks....
Okay, so tonight on my way home, I noticed that I couldn't take 1st gear up to 35 like usuall. Same with 2nd. I redline it at 25 and that's the highest my car will let me go in first gear now. And 2nd only lets me go up to 45 I think. It's like my redline changed or got messed up. So when I got home, I checked my ecu and I was throwing CEL 31. Well...According to http://www.c-speedracing.com/faq/05.php, code 31 shouldn't apply to my 97 civic. It's only for the 92-95 Prelude. I am running a P2P ecu (96-98 EX). This just started tonight and I'm kinda worried. Any thoughts?Thanks.
Old Oct 4, 2003 | 08:53 PM
VTEC-DA's Avatar
Default Re: Dropped Redline AND Code 31?WTF?I'm confused... (slvrcivic97)
Your car is probably in limp mode, and are you sure you are reading the code right?
Old Oct 4, 2003 | 08:54 PM
Default Re: Dropped Redline AND Code 31?WTF?I'm confused... (VTEC-DA)
Yeah, I quad-checked everything quad times.
Old Oct 4, 2003 | 08:55 PM
blackhatchy's Avatar
since you have a different ecu in your car, try plugging in the stock one (if you have it), and see what code it throws.
Old Oct 5, 2003 | 05:36 AM
Default Re: Dropped Redline AND Code 31?WTF?I'm confused... (blackhatchy)
Thanks for the replies. Any more?
Old Oct 5, 2003 | 06:26 AM
If it is in limp mode, will resetting the ecu make it all better again?The only thing I did yesterday was put my 2nd CAI extension peice on because I finally had a hole put in my chassis for it. I have also noticed that my car is BACKFIRING like CRAZY. Could I be running WAY to rich?Would that cause this CEL and these symptoms?Thanks.
Civic4less
20
May 30, 2005 03:10 PM
carnifex
Oct 1, 2004 10:28 AM
boost killz
Sep 7, 2001 10:59 AM
