Fuel setup & lines
this isnt a good pic, but look on the fuel rail where we tapped the guage into. you could run a line off of that with a regulator on it correct? as long as the regulated fuel pressure was less than that of the "main" fuel pressure regulater going back to the tank???
all of the b&m fuel pressure regulators i have seen for the honda's utilze the stock regulator( you gotta cut the top off of it) so it would still bolt onto the stock rail.
you might be better off getting a new fuel rail and an aftermarket regulator such as the aeromotive
<edit> Dang 2.2 is quick on the draw
You should only need a second fpr if a second fuel pump is being used. The fpr at the rail will regulate pressure for the entire fuel line from the pump to the regulator, so no matter where you tee off of, you would only be able to decrease fuel pressure below that of the main fpr if you did use a second regulator. Does that make sense?
nd94cx
Sep 16, 2004 07:03 AM
Bantam
Mar 7, 2003 08:58 AM
