what injectors?
Old Oct 4, 2003 | 05:37 PM
VtecKiDD's Avatar
Default what injectors?
i need to know what injectors i can use on a gen 2 zc obd1 motor? i have heard that you ned a high fuel pressure with the zc motor. i was wonderin if i could use civic 92-95 injectors or whether i should use 92-00 integra injectors? anyone know which is better? thanks
Old Oct 5, 2003 | 01:17 AM
Fobtions's Avatar
Default Re: what injectors? (zc-rex)
first of all they all flow the same amount unless you are dealing with aftermarket or prelude injectors. Second of all, it dpeneds on whether you are goin to be using a obd0 or obd1 ecu.
mprelude
Apr 26, 2005 05:39 AM
90 Si SOHC VTec
Jul 27, 2004 01:59 PM
b17a1teg
Jun 10, 2004 11:17 AM
phatrick2332
Jan 15, 2004 09:57 PM
Si2See
10
Jun 11, 2003 07:53 PM
