Teggy is burning oil...
Old Oct 4, 2003 | 05:30 PM
ajchen's Avatar
Default Teggy is burning oil...
as of 2 days ago i've noticed a wretched smell coming out of my car. i popped the hood and it reeked of burning oil... i checked the oil level and was down to nothing. (a month ago i was good.) looked all around the engine bay area and no sign of leaks.
i did an oil change yesterday and only got about a quart of oil out (not good, i know). threw on a new HAMP filter and synthetic 5w30 but it made the same smell after driving around for a good 10-15 minutes. a friend suggested moving up to a heavier oil but i dont think that will stop the problem per se. any suggestions?
Old Oct 4, 2003 | 05:54 PM
Rev-Olution's Avatar
is your car smoking? If it is smoking blue smoke then oil is being burned somwhere in your engine. probably check the piston rings...
Old Oct 4, 2003 | 07:39 PM
xteg95's Avatar
Default Re: (Rev-Olution)
do a compression test, is the car running normal?
Old Oct 4, 2003 | 08:13 PM
King_j's Avatar
Default Re: (xteg01)
could be many things.
check rings and valve guides
Old Oct 4, 2003 | 09:57 PM
ajchen's Avatar
Default Re: (King_j)
i'll have someone drive behind me and check my fumes...
car is running fine, power seems to be normal. i'll also do compression test.
thanks for the input. i'll report back w/results.
Old Oct 5, 2003 | 06:09 AM
Passaudi1.8t's Avatar
New User
Default Re: (ajchen)
I've got the same prob. My car runs fine, pulls as hard as any other GSR I've been in, yet it burns oil like no tomorrow. My baby burns about a quart every 800-1000 miles of hard driving, 1500+ taking it easy. It drives me nuts, and it's almost embarassing shifting at 8400 (I have an ECU) and watching a puff of blue smoke come out the exhaust. Makes me feel like I own a Dodge Caravan or something Regardless, I need a rebuild and plan on doing it as soon as I have sufficient time/funds.
Old Oct 5, 2003 | 06:15 AM
WOTTEG's Avatar
Default Re: Teggy is burning oil... (ajchen)
Check around the base off your Dip Stick t00b for leaks. this has been a problem for many honda engines. . . . the t00b comes loose and spills oil to varrying ammounts (some a little some enough to cause engine failure).
Good Luck
Jeff
Apr 18, 2005 06:23 AM
diluted
Jan 17, 2004 07:54 PM
CrazyHondaBoy
Sep 16, 2003 10:13 PM
Rydaddy
Dec 10, 2002 07:17 AM
DaeDae12
Nov 3, 2001 07:10 AM
