Oil pressure gauge
Old Aug 28, 2001 | 08:08 AM
Another B16's Avatar
New User
Default Oil pressure gauge
Has anyone installed an electronic oil pressure gauge? Can I use the existing one an just cut the wire to the idiot light or will that create some kind of code since the computer will not recognize the oil pressure?
Old Aug 28, 2001 | 09:37 AM
keithv's Avatar
Default Re: Oil pressure gauge (Another B16)
Not sure if cutting the wires would cause a code, but is the stock sender compatible with, let's say, an Autometer guage? The stock sender might not send out the right voltage levels for the aftermarket gauge...
Old Aug 28, 2001 | 07:31 PM
Gasoline Fumes's Avatar
Default Re: Oil pressure gauge (breaka_1_9)
You need to use the sensor made for the gauge.
Old Aug 28, 2001 | 07:33 PM
CRXB16aJDM's Avatar
New User
I think you can use the sender the autometer came with. Although the threading is slightly tad off, when screwing in but it'll work. But I have seen where some leaked. Autometer is bleh!
Old Aug 28, 2001 | 09:32 PM
R6Boy69's Avatar
Default Re: Oil pressure gauge (CRXB16aJDM)
http://students.washington.edu/markpaco/guages.html
departed
Jun 3, 2006 12:19 PM
95LStizzy
Mar 12, 2006 12:35 PM
Si Shane
Oct 20, 2005 02:47 PM
Mario.
Jul 9, 2004 10:27 AM
AutoXsi2000
Jul 27, 2002 06:04 PM
