Torque-Steer...what causes it??
Old Oct 4, 2003 | 03:58 PM
AndyD's Avatar
Default Torque-Steer...what causes it??
I was talking with some friends about this last night. I thought that torque-steer is caused when the tires lose traction. They said that the tires do not have to break lose to expereince torque-steer.
Your thoughts??
Old Oct 4, 2003 | 04:05 PM
Yield's Avatar
Torque steer is the tendency for the car to want to pull to one side when you accelerate hard. It's not related to traction as far as I know. I believe the main cause of it is because of unequal length half shafts so the torque gets applied unevenly. Sompin like that.
Old Oct 4, 2003 | 04:28 PM
Matgallis's Avatar
Default Re: (Yield)
i know with hondas that the right front tire is the one that does all (most) the work (driving). If you coast in first gear around 5k rpm and then u floor it.... you'll feel a dramatic pull to the right side. LSD/ATTS prevents this
Old Oct 4, 2003 | 04:57 PM
Yield's Avatar
From what I've read about it, ATTS doesn't help in a straight line. It's main function is to direct power to the outside wheel under hard cornering to help reduce understeer.
Old Oct 4, 2003 | 05:13 PM
rjr162's Avatar
Default Re: (92`Legend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92`Legend &raquo;</TD></TR><TR><TD CLASS="quote">i know with hondas that the right front tire is the one that does all (most) the work (driving). If you coast in first gear around 5k rpm and then u floor it.... you'll feel a dramatic pull to the right side. LSD/ATTS prevents this</TD></TR></TABLE>
If the right side gets power, the car would feel as if it's pulling to the left, wouldn't it?
Old Oct 4, 2003 | 05:37 PM
Cottonwoodz's Avatar
Default Re: (rjr162)
"Root causes for Torque Steer are:
• Nonsymmetric driveshaft angles, e.g. due to
o Nonsymmetric design of the vehicle, e.g. different driveshaft length
o Transient movement of the engine
o Tolerances in engine mounts
• Different driveshaft torques left to right
• Suspension geometry tolerances
• Unequal traction forces due to road surface (µ-Split) in combination with Kingpin Offset
94integragsr
Jul 18, 2005 10:36 AM
vtec_crazy
Jul 7, 2005 03:55 PM
JDMhatchback20
Dec 23, 2004 09:22 AM
otakueric
May 23, 2004 05:33 PM
JLange
Sep 19, 2002 06:40 PM
