h22a swap into a crx si... need info and lots of read up information and just help
Old Oct 4, 2003 | 03:04 PM
2003TTacoma's Avatar
Default h22a swap into a crx si... need info and lots of read up information and just help
I need lots of help and read up info on how to do a swap with a h22a1 dohc motor into a 88-91 Honda Crx si. Someone tell me what needs to be done and what work is involved such as what axles should I use, what suspension should I use and what not. Let me know I'm getting a crx si this week and probably going to throw the motor in the next two weeks. Someone told me welding had to be done and I need to know with what and where. Thanks for all your help.
Old Oct 4, 2003 | 07:16 PM
jlicrx's Avatar
Default Re: h22a swap into a crx si... need info and lots of read up information and just help (2003TTacoma)
you will need Place Racing mount kit, shift linkage, axles and cable actuator - about $1200 - you will need the transmission and ECU for the H22 - you really should get the Place Racing front crossmember to free up space - since the H22 is quite a bit heavier than the D16A6, you should beef up the front suspension
Old Oct 5, 2003 | 10:52 AM
Default Re: h22a swap into a crx si... need info and lots of read up information and just help (jlicrx)
coo thanks for the info. Is there a website where I can get place racing mounts? Also can I use the axles from a h22a prelude a 95? Will that work? What vehicles can I get a cable actuator from and what does that look like? Also can I use the h22a tranny that I have? And a p13 Ecu that I have? I'm going to upgrade my ecu cuz I'm going to do some motor mods to the engine that I'm doing. Thanks for the info you guys.
Old Oct 5, 2003 | 08:13 PM
any more info?
Old Oct 18, 2003 | 10:13 PM
SwatMan's Avatar
I'm going to to the same swap this winter but in a 4 door 89...
I know that one of the axles should be from a integra 88-89...(as seen in a topic a year ago...) don't even remember the left one or the right one...
freshly bumped thread to come to give it some health...
IS ANYBODY COULD HELP US!!!
Old Oct 21, 2003 | 12:28 PM
SwatMan's Avatar
Default Re: h22a swap into a crx si... need info and lots of read up information and just help (SwatMan)
please TTT
Old Oct 21, 2003 | 12:57 PM
roadawg's Avatar
Here you go.....https://honda-tech.com/zerosearch
Do an archived search in the CRX forum for an H22 CRX, there is a lot of info about what you guys want to do......
Old Oct 21, 2003 | 01:01 PM
Mrock's Avatar
Default Re: h22a swap into a crx si... need info and lots of read up information and just help (SiRWanabe)
You'll find lots of useful info....and LOTS of people telling you how bad an idea it is. Just stay confident, keep your eye on your goal, and you will succeed. Good luck!
Old Oct 21, 2003 | 02:00 PM
Dan Norton's Avatar
Default Re: h22a swap into a crx si... need info and lots of read up information and just help (Mrock)
I'm pleased this topic has started to come about, as i will be doing this swap aswell!
I've done a search and found some pretty good topics and threads for this swap!
And thanks to everyone who has helped with my research so far
Dan!!
Crxh22ajdm
Nov 12, 2012 09:39 AM
ThatsWutsUp
46
Jan 29, 2009 02:38 PM
203_DC5
Dec 17, 2006 12:08 AM
hatch b16a guy
Aug 15, 2005 09:25 PM
jdmvigor
May 22, 2002 07:09 AM
