dohc zc pics
Old Oct 4, 2003 | 01:55 PM
1badrex's Avatar
Default dohc zc pics
does anyone have pics if the dohc zc's 1st gens i got one with a back top but everyone tells me its a brown i cant tellby the bolt patterns somone help please.
Old Oct 4, 2003 | 02:06 PM
I8ayellowcrayon's Avatar
Are you talking about the 1G integra engines? Is it stamped ZC or does it say D16A1?
Old Oct 4, 2003 | 02:34 PM
1badrex's Avatar
Default Re: (I8ayellowcrayon)
it says zc 1st gen
Old Oct 4, 2003 | 03:20 PM
Hondasaurs's Avatar
Default Re: dohc zc pics (1badrex)
This was my 1st swap....JDM DOHC ZC
Old Oct 4, 2003 | 07:03 PM
jlicrx's Avatar
the black valve cover ZC's that fit the 2nd gen CRX and 4th gen Civic have the engine identification "ZC" & serial number stamped on the front of the block just below the head and right next to the transmission (same place as most Honda engines) - the brown valve cover ZC's that fit the 1st gen CRX and 3rd gen Civic have the engine identification "ZC" and serial number stamped on the top rear of the block, next to the transmission kind of above the starter and below the thermostat housing - they do not have valve cover bolts out beyond the edge - a black valve cover from an 88-89 integra D16A1 will bolt right on them
Old Oct 4, 2003 | 10:18 PM
Hondasaurs's Avatar
There were 2 versions of the "ZC." One version was the JDM SOHC Vtec. The other was the DOHC non-vtec. These are the only engines that had this stamped on the block. The US version was the D16A1. This is not a ZC, but the D16A1 block can be used with a JDM DOHC ZC head.
Old Oct 4, 2003 | 10:25 PM
Starbucks_91b16acrx's Avatar
Default Re: dohc zc pics (Hondasaurs)
clean swap
Old Oct 4, 2003 | 11:29 PM
AbaZ's Avatar
Default Re: dohc zc pics (91b16aCRX)
lol, well thats all I could find on my server, I know I've done way more swaps than that.. I think I've done over 20 ZC swaps for myself and others.. Good little motors
Enjoy
Oh and to answer your question, the brown tops have a different valve cover bolt config than the 2g Blacktops. The 1g "olive tops" have the same bolt config as all d16a1's. all the pics I posted are 2g Blacktops
Old Oct 5, 2003 | 06:09 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondasaurs &raquo;</TD></TR><TR><TD CLASS="quote">There were 2 versions of the "ZC." One version was the JDM SOHC Vtec. The other was the DOHC non-vtec. These are the only engines that had this stamped on the block. The US version was the D16A1. This is not a ZC, but the D16A1 block can be used with a JDM DOHC ZC head.</TD></TR></TABLE>
No, that's incorrect. There were not only 2, but rather several engines that were stamped "ZC," including SOHC non-VTEC non-OBD, SOHC VTEC OBD-1, DOHC non-VTEC PGM-FI non-OBD and OBD-1, DOHC non-VTEC non-OBD dual-carb, etc.
Old Oct 5, 2003 | 06:49 AM
USDMMARK's Avatar
Default Re: dohc zc pics (Targa250R)
never seen an olive top zc, anyone got pics???
Old Oct 5, 2003 | 07:33 AM
sparq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
DROOOOOOOOOL!
Old Oct 8, 2003 | 11:16 AM
1badrex's Avatar
Default Re: dohc zc pics (jlicrx)
i have a first gen crx and want to swap a 1st gen jdm zc but the stamp is on the front under the head and by the tranny can i use this one, if i am screwed i spent all my money on that engine fixing it up.
Old Oct 8, 2003 | 11:33 AM
RiceRacist's Avatar
My valve cover looks nothing like that but is still stamped zc
maybe because its a jdm
Old Oct 8, 2003 | 11:54 AM
dcviperboy's Avatar
the picture that someone's droolin over, look at how far the turbo is from the exhaust ports...talk about lag
Old Oct 8, 2003 | 12:29 PM
RiceRacist's Avatar
Default Re: dohc zc pics (dcviperboy)
that engine bay is ******* empty to
Old Oct 8, 2003 | 01:25 PM
91civicDXdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the picture that someone's droolin over, look at how far the turbo is from the exhaust ports...talk about lag
have you ever seen a turbo race honda by any chance? alot of them look like that.
Old Oct 9, 2003 | 12:18 PM
93AccordF22's Avatar
how are these different from the LS motors?
Old Oct 10, 2003 | 05:58 AM
4inspeed's Avatar
Default Re: (90hatchD16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90hatchD16 &raquo;</TD></TR><TR><TD CLASS="quote">how are these different from the LS motors?</TD></TR></TABLE>
well the zc is 1.6l, the b18a (LS) is a 1.8l motor.
Old Oct 10, 2003 | 07:23 AM
Targa250R's Avatar
be professional
1.6L D-series vs. 1.8L B-series.
Even though the horspower differences aren't much, the B18 (LS) produces signifiacntly more torque. They may appear to be similar, both having DOHC non-VTEC heads and similar valve cover designs, but they are actually two completely different engines.
barney_SI
Dec 6, 2009 09:37 PM
b16er
Oct 20, 2006 07:05 PM
cbstd
May 28, 2004 06:08 PM
johnjw
Mar 2, 2004 02:03 PM
Ahknodd
May 1, 2003 07:47 AM
