B16a2 Exhaust Cam Vs. B16B Exhaust Cam
Old Oct 4, 2003 | 01:01 PM
CleenSi
Guest
Posts: n/a
Default B16a2 Exhaust Cam Vs. B16B Exhaust Cam
whats the difference between the b16a and b16b exhaust cams...i have the intake cam from a b16b, should i just swap out oneof them, and go with the intake cam from a ctr, and the stock b16a exhaust cam?...i have a b16a2 BTW.
any statements would help...thanks.
Old Oct 4, 2003 | 01:07 PM
FF-sean's Avatar
Default Re: B16a2 Exhaust Cam Vs. B16B Exhaust Cam (CleenSi)
i dont get it.....??
if you have both CTR cams why would you want to swap just 1 of them??
im pretty sure this question is been covered before....
do Search my friend
Old Oct 4, 2003 | 01:11 PM
rodrez.'s Avatar
If I was going to swap out one, and I had the other available, I'd drop them both in. But if I had to buy the CTR exhaust cam, I wouldn't bother, not enough difference to necessitate the purchase.
Old Oct 4, 2003 | 01:54 PM
EG2 SiR's Avatar
Default Re: B16a2 Exhaust Cam Vs. B16B Exhaust Cam (rodrez)
why would you NOT use it if you already HAVE it? If you don't though, I am running a GSR ex. cam and it improved performance over my B16A ex. cam
Old Oct 5, 2003 | 08:56 PM
CleenSi
Guest
Posts: n/a
Default Re: B16a2 Exhaust Cam Vs. B16B Exhaust Cam (EG2 SiR)
because i dont have the exhaust cam yet.
CleenSi
Guest
Posts: n/a
BUMP
Old Oct 5, 2003 | 08:58 PM
EG2 SiR's Avatar
My buddy dyno'ed a ctr and a gsr, and they both made 1hp over stock b16. I run the gsr ex. cam and I noticed a difference over the b16 ex. cam.
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
why did you try and confuse everyone with your whole statement...it was like looking at a bowl of alphatbets cereal...i just saw a bunch of words...anyways...so basically you have a b16a2 and you have an ctr intake cam and you want to put that in correct??if you just have one and are gonna get the exhaust one soon ...you might as well wait and put both at the same time...but the intake one is the one that makes the more difference between intake and exhaust cams..if i had one cam i would just throw it in if i wasnt getting the other one anytime soon
Old Oct 5, 2003 | 09:02 PM
CleenSi
Guest
Posts: n/a
Default Re: B16a2 Exhaust Cam Vs. B16B Exhaust Cam (ciRcuitSi y0!)
sorry, i was a bit comfused myself....no reason to get all mad over it tho...but i dont plan to spend another 300$ on a CTR exh. cam, so i guess ill just stick with the stock one.
thanks for the advice guys...any other advice would help.
Old Oct 5, 2003 | 09:14 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleenSi &raquo;</TD></TR><TR><TD CLASS="quote">sorry, i was a bit comfused myself....no reason to get all mad over it tho...but <FONT SIZE="2"> i dont plan to spend another 300$ on a CTR exh. cam </FONT>, so i guess ill just stick with the stock one.
thanks for the advice guys...any other advice would help.</TD></TR></TABLE>
That's the best advice
Old Oct 5, 2003 | 09:47 PM
CleenSi
Guest
Posts: n/a
bump
Old Oct 7, 2003 | 10:05 PM
CleenSi
Guest
Posts: n/a
TTT
isumase
10
Jan 27, 2008 02:09 AM
lo0nY
Jan 19, 2006 05:31 PM
daigo
Apr 4, 2005 08:38 PM
Qwikrex
Dec 2, 2002 03:27 PM
