Subframe reinforcement
Hey guys, does anyone know of anyother brands/manufactures that make a subframe reinforcement kit (plates i guess) for the rear sway bar? I've only found Beaks that have something. Is there no other competition?
There is a sway bar setup made by Comptech that might do what you want.
If you have either a 4th or 5th gen Prelude-the sway bar mounts from Neuspeed should work as they are quite heavy. A number of Prelude owners had mount failure due to the bar being 28mm rather than 25mm. Solution was to have a frame shop weld plates in on top and bottom in some cases.
I will suggest that you have a frame/chassis shop go over the car very carefully before you buy any parts. Repair what needs repaired and then consider the choices.
Suspension Techniques won a SEMA design award for a system that does such a reinforcement, much like Comptechs. As mentioned, one can also do your own reinforcement if fabbing and welding are possible.
DarkBB4
Jan 14, 2005 03:56 PM
