how much HP gain is a DPFI TO MPFI on 89 std hb
Old Oct 4, 2003 | 01:38 AM
westcoastcat's Avatar
Default how much HP gain is a DPFI TO MPFI on 89 std hb
cuss i have a 89 std hatch, d15b1 how much hp gain do u think i will get swappin it to mpfi? thnx
Old Oct 4, 2003 | 05:20 AM
USDM 4G VTEC's Avatar
Default Re: how much HP gain is a DPFI TO MPFI on 89 std hb (blcwsfly20)
somewhere around 10 hp
Old Oct 4, 2003 | 05:32 AM
Default Re: how much HP gain is a DPFI TO MPFI on 89 std hb (USDM 4G VTEC)
10 hp that is it?? so i will be at 80 hp then>? isnt the d15b1 70 hp stock?
Old Oct 4, 2003 | 05:51 AM
yup
u might get anywhere from 80-90 hp dependin how tired that motor its
Old Oct 4, 2003 | 06:31 AM
91civicDXdude's Avatar
the d15b7 is 102hp.. its a 1.5 MPFI
Old Oct 4, 2003 | 09:07 AM
yellowcrx1991's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">the d15b7 is 102hp.. its a 1.5 MPFI</TD></TR></TABLE>
Huh?
Old Oct 4, 2003 | 09:19 AM
matt j's Avatar
Default Re: (yellowcrx1991)
ive always been curious the d15b1 is that an 8 valve motor??
civicbot's Avatar
Assuming you have a 1.5L 16-valve motor DPFI, if you install an Si head with the cam, the Si intake and ECU, of course, your HP will jump from 92 HP to about between 108-112 HP.
I did the conversion on my 89 DX hb and believe me, you can feel the difference, especially past 3 g's. Not to say you're gonna go out and hunt for GSR's, 'cause it ain't EVER GONNA HAPPEN! But it would be worth the conversion. Just don't cut wires when you do the job...get an extra Si harness and make your own from there. Then you can get the car ready for a ZC or B18a motor in the future.
Good Luck!
Old Oct 19, 2003 | 10:41 PM
kevinm1981's Avatar
Default Re: how much HP gain is a DPFI TO MPFI on 89 std hb (civicbot)
he's talking about the std not the DX, dont they have different bottom ends?
Old Oct 20, 2003 | 02:28 AM
Default Re: how much HP gain is a DPFI TO MPFI on 89 std hb (kevinm1981)
bump,, woo hoo,, yeah i had a std, 70 hp-d15b
92 hp, for the dx,d15b2
bump me again
Old Oct 20, 2003 | 03:54 AM
virginia_dude's Avatar
Yes I think the Std is an 8 valve motor like the HF, the DX and Si were 16 valve motors. fro what a ZC sells for why not just jup to that instead of trying to make a std motor into something less than even a DX engine. Just my opinion. At least get a Si or DX engine from someone who swapped, less work and not much cash.
Old Oct 20, 2003 | 03:56 AM
?????????? The STD engine has FAR less power than the DX that had like 92hp. whereas the Si was about 106, STD was about 70-74 roughly, but by no means was a 8 valve STD engine pushing anywhere near what the Si 1.6 was doing.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">the d15b7 is 102hp.. its a 1.5 MPFI</TD></TR></TABLE>
Old Oct 20, 2003 | 07:05 AM
Civmochris's Avatar
Default Re: (matt j)
not all std are 8 valve i have a 91 std and it is a 16 valve with the dpfi
Old Oct 20, 2003 | 07:12 AM
phatrick2332's Avatar
ok fellas..there not 8 valves, there a 16 valve. The b1 actually has higher compression than that of the Si also. The head is identical to the Si. Do the mpfi swap alone and look at numbers right around 100-105 hp, depending on how good ur bottom end still is. Swap the Si cam and u will be at about 108 hp. After you do the mpfi swap, put an si tranny in there, and smoke stock Si's all day long.
Old Oct 20, 2003 | 07:18 AM
I was comparing his MPFI D15B1 to a D15B7, which is a 1.5L SOHC MPFI 16v. same setup.
D15B1 is 16v. D15B1/D15B2/D15B7 all have the identical pistons, flat tops with 4 valve reliefs. since the d15b7 is rated at 102hp, and the d16a6 is rated at 108hp, im guessing that his 1.5L SOHC MPFI will be somewhere around 95-105hp
Old Oct 20, 2003 | 11:51 AM
Well you guys have me lost now, I got away from the 1.5 anything when I found my cylinder walls scored, and went ZC DOHC. I will bow out of this discussion till it gets back into territory I understand better.
Old Oct 20, 2003 | 02:25 PM
Default Re: (virginia_dude)
bumpy bump bump.. yeah, i got it nw, my 89 std is 16 valve, i am gonna order a zc from HMO.. what do u gys think? good idea?
Old Oct 20, 2003 | 02:50 PM
1CiViC1's Avatar
Default Re: (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">Swap the Si cam and u will be at about 108 hp. After you do the mpfi swap, put an si tranny in there, and smoke stock Si's all day long.</TD></TR></TABLE>
after the a6 head and mpfi swap. the gains were minimal, but the throttle response and idle definitely improved. The key is to ditch that 4spd, thats the real problem...
TrickHonda98
Jun 28, 2004 01:39 PM
subgeniusdude
19
Mar 12, 2004 04:21 AM
westcoastcat
Oct 5, 2003 09:08 PM
