camber kit problems in crx
well i lowered my crx with some progress lowering spring and i went to install my camber kit and it wouldnt work! when i put it on the end of the upper suspension arm wouldnt clear the inside lip of the wheel well. do i have to do something to make it fit? anyone else have this problem?
TIA
TIA
same thing happened to me with my ingalls kit... i heated the unibody up with a torch and beat the hell out of it with a ball ping hammer until it cleared... worked great
i also have the progress camber kit. I had the same problem, but i just pounded the lip out about a 1/4 inch and it fit barely. Once it passes that part you will be fine.
