replacing an oil pan
Old Oct 3, 2003 | 10:45 PM
o d i e e's Avatar
Default replacing an oil pan
is it an easy fix ?? i was driving with some of my friends through the canyons and we ran into a patch of rocks which looked to be set out on the road purposely...my friend in his rx7 which is jsut as low as mine was able to go over it ok but after i went over it it put a hole in my oil pan. yes i know i should have tried to avoid the patch but if my friend in his 7 could make it over then i thought i'dbe able to as well. guess not...people that put things on the road suck.
Old Oct 3, 2003 | 10:47 PM
PotatoePAPA's Avatar
Default Re: replacing an oil pan (EK-driveR)
yes its a fairly easy process...just make sure you replace the gasket and that the surface is clean before putting it on (i.e. the original gasket taken off, and clean the surface with rubbing alcohol)
Old Oct 3, 2003 | 11:00 PM
aw1234dude's Avatar
Default Re: replacing an oil pan (SleepyDX)
how big of a hole did it leave?
Yeah, Ive replaced a couple of oil pans and its very true that you must clean both surfaces. I used acetone (paint thinner) to clean the surfaces, alchohol should work as well. I would also use a new gasket because you wouldnt want to risk it with the old one. Also use some kind of high temp auto silicone sealant like ultra grey or ultra black.
Old Oct 3, 2003 | 11:17 PM
o d i e e's Avatar
one more thing...after the rock put the hole in my pan oil sprayed all over the rear of my car and on to my friends car behind me as well...is it easy to clean the oil off my car? any recommendations as to what i can use to it wont be greasy and stuff ?
Old Oct 4, 2003 | 07:28 AM
o d i e e's Avatar
no suggestions ?
Old Oct 4, 2003 | 07:37 AM
JICEK9's Avatar
cleaning won't be to bad. just get some heavy duty degreaser and some hot water and as far as replacing the pan, just drain the oil (or the rock did that for you ) then take off all the nuts and remove the pan. you won't have to clean the pan like stated above because it's junk, right? so take your new gasket and pan and reinstall
Old Oct 4, 2003 | 07:44 AM
CoolKat's Avatar
my service manual says the same thing like the other guys, clean the pan and engine surfaces with either acetone or laquer thinner, and then just get a new gasket, make sure to put some RTV sealant on it too, and tighten it down in a spiral direction.
Old Oct 4, 2003 | 08:15 AM
SICKSOLSI's Avatar
Default Re: replacing an oil pan (CoolKat)
just make sure its torqued correctly
Ef4doorwagon
21
May 13, 2014 04:02 PM
j4s0n1337
Nov 24, 2011 08:31 PM
TheOdd001
Feb 10, 2010 12:26 PM
StreetRacinThug
Dec 21, 2006 08:44 AM
LAKER HATER
May 17, 2004 10:49 AM
