CEL code 10 ..where is it?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhatchalot5 »</TD></TR><TR><TD CLASS="quote">i have a cai...also this is on a GSR swap
thanks</TD></TR></TABLE>
Did your forget to plug it into the CAI?
I thought the IAT was located on the 1st cylinder intake runner. From my memory of the plug, it is white in color. Let me find a pic of mine.
do you have a manual for the is a procedure how to check your iat. it could be your fast idle thermo valve need to be clean and adjust. but do the idle speed setting first then check your iat problem. rest the ecu then set the idle speed then see drive around to see if cel come on with the same code or not. before you go buy any sensor. that my 2 cent.
beedoublejay
Aug 21, 2005 03:28 PM
