96 Honda Accord ABS Light Question
Old Oct 3, 2003 | 10:12 PM
Neldawg's Avatar
Default 96 Honda Accord ABS Light Question
For all you accord owners....i'm sure this topic was covered before..... but have any of you had a problem with the ABS light?
I always thought it was just a sensor behind one of the wheels.....but my mechanic checked it out and all the sensors looked alrite....and also the ABS works....so I don't know why the light comes on every so often......any ideas?
Thanks
Old Oct 4, 2003 | 06:52 AM
Chiovnidca's Avatar
Default Re: 96 Honda Accord ABS Light Question (Neldawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neldawg &raquo;</TD></TR><TR><TD CLASS="quote">....so I don't know why the light comes on every so often......any ideas?
What code does it have stored? Check it the same way you would a CEL.
Old Oct 6, 2003 | 10:21 AM
Neldawg's Avatar
Default Re: 96 Honda Accord ABS Light Question (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
What code does it have stored? Check it the same way you would a CEL. </TD></TR></TABLE>
hmm...not sure what the code is and not sure what a CEL is...sorry
ABS works...just the light comes on every now and then........is there anything that I can do on my own to fix that problem?
Thanks for your input tho..i appreciate it
Old Oct 6, 2003 | 11:28 AM
Accord_Munch's Avatar
If your light is on, from what I know, your ABS is NOT working .. you brakes work of course. When your light is on, you car reverts just to normal 4-wheel disc mode. Pull the ABS code ... I have problems with my ABS light coming on from time to time, I have a leak in the ABS system. So I have to fill the resevoire (sp?) up from time to time.
Old Oct 7, 2003 | 10:40 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neldawg &raquo;</TD></TR><TR><TD CLASS="quote">hmm...not sure what the code is and not sure what a CEL is...sorry</TD></TR></TABLE>ABS computer stores an error code just like your ECU does when it light up the check engine light (CEL). Procedures for reading the code might not be the same for all years, so someone who has a 5th-gen can go for that...
Some ABS faults happen when the ABS still works. For example my Integra will light up the ABS light if it takes too long to pump up the accumulator. Or if it has to pump it up again without having used the ABS. But the ABS still works...
typeR564
Feb 26, 2007 10:35 PM
Neldawg
Jan 13, 2005 04:01 AM
jweezy225
Aug 5, 2004 09:56 PM
Ls-Rturbo
Apr 5, 2004 02:01 PM
Neldawg
Nov 23, 2003 06:28 AM
