quick fuel pressure regulator question
ok, heres the scoop
its a d16a6 with a Z6 mani, B16 TB ,Z6 fuel rail and A6 injectors
is there any difference between the Z6 and A6 FPR's?
Just wondering which one to go with. I'm using the Z6 FPR right now and its running a little on the rich side.
You think that by using the A6 FPR , it might possibly lean it out a little?
just wanted to get some input before i tried it.
TIA
mike
TIA
mike
no there isnt a difference, its all 1.6 so yeah u are in great shape, maybe might lean a little, get a fuel/air ratio gauge, at pepboys, looks sickmade! and its like under 20 bucks, so slap that **** on and adjust ur idle and air screw on the intake manifold
If I'm not mistaken, the Z6 one is different from the A6 one. I think the Z6 one does run a little richer to compensate for VTEC. I think the only real way to know is to use a wideband O2 and see the air/fuel ratio differences (if any) between the two FPR's.
pornstarSR
Aug 6, 2003 09:01 PM
crx(gator)
Jul 21, 2002 07:57 PM
