CRX obd0 ecu
Old Oct 3, 2003 | 06:45 PM
shawn_crx's Avatar
Default CRX obd0 ecu
I need your help. Going to swap an 96 LS in there. Could I keep it as OBD0 and use an 90-91 teg and then chip the ecu?
Or is it better to convert to obd1 or 2?
Old Oct 3, 2003 | 06:51 PM
4crx4me's Avatar
Default Re: CRX obd0 ecu (shawn_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">I need your help. Going to swap an 96 LS in there. Could I keep it as OBD0 and use an 90-91 teg and then chip the ecu?
It all depends on the circumstances and your budget and how much work you want to do.
What OBD is the car, that the engine is going into?
Do you have OBD0 parts laying around?
And what wire harnesses are you getting with the engine?
And how comfortable are you with the wiring changes?
for me. Didn't see the "CRX" in the topic.
So it is OBD0. but is it an Si?
Old Oct 3, 2003 | 07:09 PM
shawn_crx's Avatar
Default Re: CRX obd0 ecu (4crx4me)
Sorry, It's and CRX HF obd0
Old Oct 3, 2003 | 07:18 PM
4crx4me's Avatar
You could convert the engine to OBD0......OR convert the CAR to OBD1 or 2. That's up to you.
To convert the engine, you'll need an OBD0 ECU, dizzy, and injectors.
And use the resistor box that's already in your car. A little rewiring and you're done.
But from ALL I've read, here on HT, it might be better to convert the car to OBD1.
Old Oct 3, 2003 | 07:41 PM
shawn_crx's Avatar
what is the difference between obd1 and obd0. Still going to chip them.
Old Oct 3, 2003 | 07:47 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">what is the difference between obd1 and obd0. Still going to chip them.</TD></TR></TABLE>
What do you MEAN by difference? Difference in what regard?
What are you trying to accomplish?
Old Oct 3, 2003 | 07:52 PM
shawn_crx's Avatar
What would i gain from going to OBD1.
If I stay on OBD0 I just need dizzy, and injector, and an ECU.
If I go to OBD1 i need to get wire harness. and dizzy, injector and ECU.
The point is it save me time and money from getting the wire harness.
Old Oct 3, 2003 | 07:59 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">What would i gain from going to OBD1.
If you plan on leaving the car somewhat stock and using it as a daily driver, and not putting a VTEC engine in it, you CAN stay OBD0. It WILL be cheaper than going to OBD1, in the short term, if the engine you are putting in does NOT come with any OBD1 extras, like dizzy, ecu, etc.
gsrpowercrx
Engine Management and Tuning
Nov 9, 2008 06:54 PM
nelsonb16
Jan 31, 2008 06:41 PM
BIG_T
Aug 15, 2007 06:12 PM
FOMULA91
Jul 18, 2005 01:31 AM
firstgenrex
Mar 4, 2004 02:39 PM
