Heat shields needed on JDM 4-1?
Old Aug 27, 2001 | 09:59 PM
R264's Avatar
Default Heat shields needed on JDM 4-1?
Will not having the heat shields on the JDM 4-1 header cause any damage? What exactly is their purpose?
Old Aug 27, 2001 | 10:02 PM
Chris's Avatar
Default Re: Heat shields needed on JDM 4-1? (R264)
To keep unwanted heat AWAY from the motor. No damage.
Old Aug 27, 2001 | 10:14 PM
geometro's Avatar
Default Re: Heat shields needed on JDM 4-1? (Chris)
If you want to break it down to nit picking, it helps keep heat "in" the header so the exhaust gasses stay hot...and velocity stays up there. % difference when running without a header? Probably negligible.
The other thing about keeping heat "in" (besides "away" from the motor) is away from the radiator and the AC lines (if you still got 'em). The heat jacking up the foam on the AC line is a long long LONG term effect.
If you got the option to have heat shields, run 'em. If not, it's all about HPC or JetHot...
-Geo
Old Aug 27, 2001 | 10:17 PM
Chris's Avatar
Default Re: Heat shields needed on JDM 4-1? (geometro)
Thanks Geo!!!
InfamousLude
Jul 19, 2005 12:33 PM
SLeePeR012
Feb 21, 2004 06:57 AM
jdmb18c
Feb 20, 2004 06:46 PM
StinkyTofu
Nov 5, 2001 09:05 PM
onyx00
Sep 22, 2001 02:50 PM
