Ground Control coilover problem
Old Oct 3, 2003 | 04:12 PM
BLK99VTECR's Avatar
Default Ground Control coilover problem
today i got to raise my car up so i start with the left side. To my amaze ment and loosin the the screw AND taking the screw out, the adjuster disk thing would not move freely. So i spray it wit water then WD40 and i get the same results. Finally i get desperate and the side to take a screw driver and harmer it into the groves in the direction of up which did move it while i was hammering wit but after that it would still not move freely by hand. So then i decide to give up on the wheel and try the right side and to my surprise again, i had the same results as the previous side repeating the same steps. Only thing that I can tell u all is that i have just recently gotten an engine swap,( but right after i got it i was still able to adjust the coilovers), and that its colder now, and frankly my alinment has been off real bad since i got the car back. If anyone can make any sense of this and tell me what to do then please help.
Old Oct 4, 2003 | 03:10 AM
BLK99VTECR's Avatar
Default Re: Ground Control coilover problem (BLK99VTECR)
Old Oct 4, 2003 | 10:15 AM
PupaScoopa's Avatar
You mean the collar that goes around the threaded sleeve? Do you feel any grit in it? Somtimes dirt can sieze it up; so you have the right idea with WD40. Try prying the opening apart a little once you remove the pinch bolt.
Old Oct 4, 2003 | 10:19 AM
-Gambit-'s Avatar
Default Re: Ground Control coilover problem (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">You mean the collar that goes around the threaded sleeve? Do you feel any grit in it? Somtimes dirt can sieze it up; so you have the right idea with WD40. Try prying the opening apart a little once you remove the pinch bolt.
yup what he said.
Old Oct 4, 2003 | 10:21 AM
VX's Avatar
VX
Default Re: Ground Control coilover problem (Evil_gambit33)
I had trouble adjusting mine too, so i ordered a $3 spanner wrench from Ground-Control. Problem solved.
Old Oct 4, 2003 | 11:23 AM
Bailhatch's Avatar
Default Re: Ground Control coilover problem (VX)
I use brake cleaner first and brush all the threads in the direction you plan on going. After it is all clean i use a penetrating lube like PB blaster and, like everyone said spread the ring if it is a clamp type adjusting ring. The plastic brush and blow gun @ 100psi is key.
Old Oct 4, 2003 | 07:58 PM
BLK99VTECR's Avatar
Default Re: Ground Control coilover problem (Bailhatch)
i might look into buying that little wrench thing. Imma give it another try monday when i swap my wheels back.
Old Oct 4, 2003 | 09:01 PM
FcUK It.'s Avatar
everyone has that problem, my friends sleeves were so dirty, so i used brake cleaner and wd-40 and wiped it with a towel, it began to give a little. patience is the key
Old Oct 4, 2003 | 09:46 PM
HATCHingMN's Avatar
Default Re: (frosteg6)
Last time I use a flat screwdriver to turn the collar up and down, but instead of hammer it down I use two tool (flat screwdrivers) to act like a adjuster ranch!! it work for me, give it a try.
Looks like it needs a dust cover or some sort.
Old Oct 4, 2003 | 10:08 PM
96 SOHC VTEC's Avatar
Default Re: (HATCHingMN)
Get some gloves and use some strength. They are usually a bitch to turn, but after some WD-40 and a little elbow, I always get it going.
newbbb
Oct 22, 2008 02:16 AM
xaznxdrgnxboix
Suspension & Brakes
10
Jun 8, 2007 10:13 AM
slowr6
Suspension & Brakes
Jan 27, 2005 05:12 AM
BLK99VTECR
Oct 4, 2003 08:55 PM
djay86
Jul 31, 2002 08:06 AM
