Launching Falkens?
Just got a new set of Falken Azenis and at 3K I bog, at 4K they blow off. WTF I also tried to launch it around 5K and feather the clutch, but I got a lot of wheel hop. I know these aren't the best tires for drag, but I thought they would be better than that. Do you think they were not warm enough? It was kinda cold last night...
i read of people dropping the tire pressure to like 18-20psi and dropping the clutch at like 3500Rpm-4000Rpm and getting really good 60" times.....
Go and search "azenis" .. u will find alot of info....
Cool I will try that! It's not too bad I mean I pulled consistant 2.3 60' but I did better than that on the stock tires Kumho 711 (yuck). I think I just need to get them a little warmer and get used to them!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibspecHATCH »</TD></TR><TR><TD CLASS="quote">At 22psi on Azenis...launching at 5200rpm..feathering the clutch...2.1s.
Rod</TD></TR></TABLE>
26psi.......5500.....slight feather......2.1s
run slicks you hit 1.8
We are all running Azenias and RA-1 best way we found for low ets was 20-25psi and NO BURN outs just spin the tire to get the rocks off and I was getting 2.0 and 1.9 with My 4 door Turbod EL
20 psi, hard slip from 5500= low 2.1's
and try to not heat them up, they grip better when cold. if you can go around the water box, do so. if you can't, just do a small burn out to get the water off.
azenis do not grip better when cold i will tel you that......i have never spun through third gear untill a cold night at a shitty track......i ran 14.5s and a high 10 sec all motor crx running 12s......hahahahha
I'm pulling the same on Yoko ES100s..... I usually see the azenis in the 2.0 range.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhybrd »</TD></TR><TR><TD CLASS="quote">azenis do not grip better when cold i will tel you that......i have never spun through third gear untill a cold night at a shitty track......i ran 14.5s and a high 10 sec all motor crx running 12s......hahahahha</TD></TR></TABLE>
i will disagree with you on that until the cows come home. i have always had worse 60' times when i did a burnout compared to not doing one. if it works for you though, go for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeremyEG »</TD></TR><TR><TD CLASS="quote">
i will disagree with you on that until the cows come home. i have always had worse 60' times when i did a burnout compared to not doing one. if it works for you though, go for it.</TD></TR></TABLE>
I'd think most agree, street tires need a teeny bit of heat. Best bet isnt a burnout or completely cold. Just spin them to clean them off and that'll do the job.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER »</TD></TR><TR><TD CLASS="quote">
Yea I know...haha. On the slicks I picked up from you...I run 1.8s.
</TD></TR></TABLE>Yea I know...haha. On the slicks I picked up from you...I run 1.8s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">
I'd think most agree, street tires need a teeny bit of heat. Best bet isnt a burnout or completely cold. Just spin them to clean them off and that'll do the job.</TD></TR></TABLE>
if i have to go through the water box, i just give them a tiny cleaning before the launch.
JerseySiPOS
Apr 1, 2004 04:52 PM
