gsr exhaust on ls
Old Oct 3, 2003 | 11:13 AM
InTeGrA_bLazEd's Avatar
Default gsr exhaust on ls
are there any benefits to putting on a gsr exhaust on a ls?
Old Oct 3, 2003 | 11:16 AM
patmcd's Avatar
Default Re: gsr exhaust on ls (InTeGrA_bLazEd)
no, they are the same size.
Old Oct 3, 2003 | 11:18 AM
Default Re: gsr exhaust on ls (patmcd)
so there wont be any benefits?
Old Oct 3, 2003 | 11:35 AM
patmcd's Avatar
no, because the diameter of the piping is the same. If its pre 2000 (i think that year) then the exhaust wouldnt bolt right up with out some custom welding. The reason for this is the b18b and b18c1 have differnt A-pipe lengths. The ITR exhaust is larger, and would give some gains. The RS, LS, GS, SE, GS-R exhausts range in diameter from 1.91-2.0 inches depending on year. Where as the ITR exhaust is 2.25 inches for all models.
Old Oct 3, 2003 | 01:00 PM
wall of tvs's Avatar
Like others have already said, it won't bolt up unless you do some custom fabrications to the a-pipe.
Old Oct 3, 2003 | 01:22 PM
patmcd's Avatar
Default Re: gsr exhaust on ls (wall of tvs)
Which in my opinion is a big waste of money. If you want the stock look with a larger diameter, get the ITR exhaust.
Old Oct 3, 2003 | 01:31 PM
Sliminem's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patmcd &raquo;</TD></TR><TR><TD CLASS="quote">Which in my opinion is a big waste of money. If you want the stock look with a larger diameter, get the ITR exhaust. </TD></TR></TABLE>
either that or look at others out there for the RS/LS/GS, there are plenty out there.
Old Oct 3, 2003 | 05:08 PM
sdchump's Avatar
Default Re: gsr exhaust on ls (Sliminem)
actually its the cats that are different. LS/ITR have the same length and the GSR has a shorter cat. i have a 96 gsr and have put an ITR exhaust on my car. i had to extend the B-pipe by a few inches to make it work. the ITR is much better, larger diameter and smoother(mandrel) bends in the piping. my stock gsr exhaust was all pinched with a smaller diameter. go with an aftermarket exhaust or an ITR like everyone else has suggested.
lPat
Oct 5, 2007 02:04 PM
EvilJunkee
Apr 11, 2007 01:18 PM
mikey1987
Dec 9, 2004 06:34 PM
StayTuned12
Sep 13, 2004 04:19 PM
redteg1
Jan 24, 2002 06:23 AM
