What are the symptoms of a broken motor mount?
Some of the symptoms of a broken motor mount are kind of obvious. First off when you shift some what at hight rpms fast you will hear a clank or popping noise. Also your motor tends to vibrate a bit more. Just pop your hood and look at the mounts, if you see any oil around the mounts they are done.
I think I was the first RSXS to bust his motor mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exzeltus »</TD></TR><TR><TD CLASS="quote">Another sympton: steering wheel shakes when at a standstill/stop. Once you get going, it stops vibrating.</TD></TR></TABLE>
Unless you have the J's damper or the ES motor mount inserts, thats normal.
g2teg27
May 22, 2011 10:18 AM
