h23 w/200k mi+nitorus
Old Oct 3, 2003 | 07:12 AM
SKDRCR's Avatar
Default h23 w/200k mi+nitorus
how long do you guys think the engine would hold up if i put nitrous
in it, say a 50 shot or so
i have a b&m ffm if that helps me at all
Old Oct 3, 2003 | 07:59 AM
PrecisionH23a's Avatar
Default Re: h23 w/200k mi+nitorus (SKDRCR)
My guess would be not that long. First and foremost, do a cylinder leakdown test. If you yield good results then maybe a small 50 shot will be ok. I would also add a nice ignition system to your set-up as well as retard the timing about 2 degrees and colder spark plugs.
Old Oct 3, 2003 | 09:42 AM
SKDRCR's Avatar
Default Re: h23 w/200k mi+nitorus (GudeH23a)
Koo, yeah i did a compression test (i know there pretty inaccurate )
but it read 140 140 135 145------pretty low
do you run nitrous also or just turbo boss hoss
Old Oct 3, 2003 | 10:52 AM
01GSRcpe's Avatar
My friend with a 91 civic SI decided to go nitrous at 215k miles on the original motor. Hes been through 3 bottles (ZEX kit 55 shot) so far and no blown engine yet. But of course looking at your compression numbers it wouldnt be the best idea. Good luck with it.
Mike
01GSRcpe
Old Oct 3, 2003 | 03:13 PM
SKDRCR's Avatar
Default Re: h23 w/200k mi+nitorus (01GSRcpe)
yeah my friend had close to 200k on his orig motor
and he went through about 10 bottles b4 his went kaboom
and he had a best time of 13.2 w/slicks
Old Oct 4, 2003 | 05:53 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">My guess would be not that long. First and foremost, do a cylinder leakdown test. If you yield good results then maybe a small 50 shot will be ok. I would also add a nice ignition system to your set-up as well as retard the timing about 2 degrees and colder spark plugs.</TD></TR></TABLE>
Retard the timing on the intake or exhaust side?
ArmaanOG
Mar 11, 2009 10:22 AM
ken00si
Oct 11, 2005 04:49 PM
D.A.luder
Feb 17, 2005 04:07 PM
92blackprelude
Sep 9, 2004 08:05 AM
BLACK_DEL_SOL
Aug 17, 2004 04:44 PM
