CG-Lock?
I have no idea what that is, but a simpler and cheaper solution is to move your seat back a click or 2, give the seatbelt a twist before you click it in and then move the seat back up to where it was.
Cheers,
Roy
Cheers,
Roy
Doh! Forgot the link/pics
I was too tired to be posting last night
There's an ad in the October issue of SportsCar
I'm looking at this as a cheap way to improve the "performance" of the stock belt. Twisting the belt doesn't work as well as I would want it to sometimes...
i still dont understand how locking the factory seat belt at the tongue locks the retracting mechanism, in the case of a crx, it has two retractors on the shoulder and lap, but then, maybe the crx is considered one of the cars it isnt compatible with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">i still dont understand how locking the factory seat belt at the tongue locks the retracting mechanism, in the case of a crx, it has two retractors on the shoulder and lap, but then, maybe the crx is considered one of the cars it isnt compatible with.</TD></TR></TABLE>
its tricky but you can tug on the belt , lock both retractors and twist to keep tension.
very hard to get right but I did that before I had harnesses.
I used to put the seat back all the way back, click in the seatbelt.
Then tug the belt quickly to lock it, then bring the seat back up and you are sandwiched.
Need a little more, slide the seat up a bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">yeah, but how does a contraption like the cg lock help?</TD></TR></TABLE>
no clue.
junk and a waste of money IMHO.
no clue.
dank714
Jan 22, 2014 05:28 PM
or
