won't go into reverse
Old Oct 2, 2003 | 08:47 PM
metal-x's Avatar
Default won't go into reverse
My gsr tranny won't go into reverse could it be my synchros? what are the odds the reverse gear would go!
Old Oct 2, 2003 | 08:54 PM
garados's Avatar
Default Re: won't go into reverse (metal-x)
does it grind? when was the last time the tranny fluid was replaced?
If the fluid hasn't been replaced, do it with honda mtf or gm synchromesh? or something like that. Usually that will get rid of some problems. About teh reverse gear, it's a small gear, about an inch in diameter on a shaft aobut a quarter of an inch in diameter. I don't know how strong it is, but I don't think it would go out... unless you do burnouts in reverse
Old Oct 2, 2003 | 08:56 PM
Bill Hook's Avatar
I don't believe reverse is synchronized. Make that know - who wants to synchronize reverse to the forward gears? To make it easier to ruin the transmission?
It is a straight cut gear, which could affect how easy it is to engage, and there is a lockout that helps keep it from engaging while moving. Try double clutching to get engagement or shifting to first then reverse.
Old Oct 3, 2003 | 06:21 AM
metal-x's Avatar
Default Re: won't go into reverse (Bill Hook)
I have tried shifting through the gears but reverse still won't engage it seems as if something is blocking the gear
guys thanks for the advice, I will drain the tranny fluid today and replace it see if that makes any difference
Old Oct 3, 2003 | 06:59 AM
NeoGSR's Avatar
how's 5th gear?
i know my tranny was messed up like that, if you try to shift it into 1st and then go into reverse, it'd work......something like the interlocks or something was messed
Old Oct 3, 2003 | 10:43 AM
R.S.'s Avatar
Default Re: won't go into reverse (NeoGSR)
sum times i can't get it into reverse so i shift into 4th then put it into reverse and it goes in easier, but i have a LS tranny so i don't know if it's the same prob (it's not my tranny fluid either cuz i changed that wit Honda MTF not to long ago).
Old Oct 3, 2003 | 11:12 AM
99civic_exSB's Avatar
Default Re: won't go into reverse (-R-)
Try letting the clutch out a little bit and see if it slips in. That's what I do with mine.
Old Oct 3, 2003 | 12:03 PM
nospeedlimit143's Avatar
the reverse idler gear may be stuck, or the arm that places it between the main and countershafts might be out of place. somethings not right if its not going in. if you try changing the fluid and that doens't get you anywhere, its time to pull it apart and see whats going on in there.
Old Oct 3, 2003 | 01:01 PM
JOSEPH's Avatar
i've had the same problem a few weeks ago. open up the tranny casing and you'll see that its either the bearings or gears are broken.
btw, reverse doesnt have synchros.
Old Oct 3, 2003 | 01:23 PM
Hybrid Invasion's Avatar
Weird thing, but I had a similar problem, but it turned out that I would back up fine in reverse, then go to throw the car in 1st and it wouldn't move anywhere. Turned out to be that when I did my swap and popped my axles in, the retainer clips I bought new, weren't properly stretched, thus not grabbing the spindle and my passenger side axle was coming out of the spindle, so my car wouldn't go anywhere. Took the axles out, bent the retainer clips a little bit, then my axles seated properly and didn't have the problem again.
If it's a problem with the car going into reverse, it's not gonna be a synchro because reverse doesn't use a synchro, hence the reason why you need to put the car into another gear before popping it in reverse to prevent grinding. It's probably what the other guy said, the reverse idler thingy. That sounds like it makes the most sense to me. Take it to an import tranny specialist if you just can't figure it out.
Old Oct 3, 2003 | 02:01 PM
Jet Black's Avatar
Default Re: won't go into reverse (Hybrid Invasion)
It doesnt go in even if you double clutch dude???
Mine never goes in the 1st time...allways double clutching it in
Old Oct 3, 2003 | 02:47 PM
Default Re: won't go into reverse (Jet Black)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black &raquo;</TD></TR><TR><TD CLASS="quote">It doesnt go in even if you double clutch dude???
Mine never goes in the 1st time...allways double clutching it in</TD></TR></TABLE>lol um... i don't double clutch.. not a roadracer or a truck driver I don't have that problem anymore.
Old Oct 3, 2003 | 04:01 PM
Jet Black's Avatar
? explain
Old Oct 3, 2003 | 04:08 PM
TeamSTEALTH GSR's Avatar
try to go half way to 5th then to R.
maybe loose linkage?
Old Oct 3, 2003 | 04:41 PM
The-LS's Avatar
Default Re: won't go into reverse (TeamSTEALTH GSR)
had a similiar problem on my stock clutch, was running 200whp on it for a while and I broke a spring off the clutch plate and it was bouncing around in my tranny causing my clutch to stay STUCK engaged SOMETIMES. so 20% of the time I can shift, 80% I couldn't.
Old Oct 4, 2003 | 10:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black &raquo;</TD></TR><TR><TD CLASS="quote">? explain</TD></TR></TABLE>what is there to explain, exactly? I don't doubleclutch, and I don't have the problem with the tranny anymore; I fixed it.
Old Oct 4, 2003 | 12:58 PM
wall of tvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x &raquo;</TD></TR><TR><TD CLASS="quote">My gsr tranny won't go into reverse could it be my synchros? </TD></TR></TABLE>
Reverse has no synrhros.
deejae
Nov 16, 2013 02:39 PM
ClemsonME
16
Aug 18, 2009 10:09 PM
elevatethis
41
Nov 24, 2003 12:02 AM
RTW DC2R
Sep 14, 2003 06:02 AM
Lo-Buck EF
11
May 31, 2002 06:43 PM
