how to make a 150k mile motor run like new?
well, sadly enough i'll be putting the miata in storage in the next couple weeks, so i'm beginning to plan out my winter projects. one of them is to make my motor not run like a POS. i'm sick of getting blown by on the straights like i'm standing still in what is supposed to be a 'spec' class.
now, i know i could buy a crate motor, but coming up with 2 grand is easier said than done. i could buy a motor out of a junkyard with like 50k miles or so, but then i really don't know how good that motor is either.
basically what i'm asking is what i need to include on a rebuild to strengthen this guy back up. keep in mind my current goal is to get to the middle of the pack, instead of mixing it up with the guys in the back. but at the same time, if there are simple and/or inexpensive things that start to get close to factory tolerances on various things, i'm willing to do that.
(i suppose i should fix my clutch MC first)
Hey how about a nice basic list of engine parts for a rebuild while someone is "at it". I will need to rebuild my Integra motor soon but besides some of the obvious I am afraid to miss anything critical.
Winter projects make life worth while.
Would it be a good idea to take any worn holes, bore then and add in sleeves where necessary? I hear it is easier in the event you have to replace certain parts you bust while racing.
I am going for a full rebuilt, all of the seals and such plus some performance parts swapped with the old OEM ones. I personally plan on upgrading the valvetrain as part of my rebuild.
Refresh the head to perfect factory specs.
Re-ring pistons and possibly hone cylinder walls.
New bearings (depending on mileage).
And then the fuel and ignition systems (new cap/rotor, fuel filter, plugs, wires, etc).
Balance/clean fuel injectors.
Buy a balance, scales and baskets full of new OEM parts...
Oh, wait - you meant ONE winter's worth of work! Nevermind.
K
K
All you need on the Miata is to freshen the head. I finished 10th in a scca pro race with a 120K mile motor, a fresh head, and a failing wheel bearing. Unless your cylinder walls are scored the looser the bottom end the better. Buy the top end gasket set from Mazda Comp for $115, a new set of springs, and any valves you have that might be fried. Sometimes the lifters die too, but if your car does not tick after it has been to redline and back those will be OK. A little machine work to have the seats done and you will be ready for hours of hand lapping valves :-) Rebello will also do the work and assembly for about $800 plus the cost of the above stuff you may need.
Have fun!
Have fun!
Your engine may be down on power, but there are other factors that contribute to a car's top speed. If you speed entering the straight is down, your top speed will be as well.
Just keep that in mind. Adjusting the suspenion and improving your driving are virtually free. Make sure your chassis and driving are on even terms with the competition before spending alot of money on something that may not make much of a difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">how to make a 150k mile motor run like new?</TD></TR></TABLE>
put someone in the car that knows how to drive. You might find that fixes some of the biggest motor problems. If you are getting blown by on the straights, it *might* be partially the motor but it ain't all. And you are not in a "supposed" Spec Class, you ARE in a Spec Class. It simply doesn't specify Spec Drivers.
I agree with Rice and Phat... If possible the engine should be the last improvement made. The first of course is the driver. I'd drive the old engine until I HAD to fix it...
Modified by bulldog_RS20 at 9:10 PM 10/3/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulldog_RS20 »</TD></TR><TR><TD CLASS="quote">I agree with Phat... If possible the engine should be the last improvement made. The first of course is the driver. I'd drive the old engine until I HAD to fix it...
From the looks of this guys other post, I think its the car, not him.
</TD></TR></TABLE>From the looks of this guys other post, I think its the car, not him.
Oh, I read it as he wanted more power as opposed to needing to fix his engine...
One of the best training tools to a new driver is an underpowered car. I went 1.5 seasons on a weak stock motor before I HAD to replace it, and it taught me a ton...especially the importance of exit speed - which a few folks touched on.
I see way too much $$ spent on built equipment and not enough focus on driver development. If your excuses for performance start with "If I only had..." then you're probablly going about it the wrong way.
Just my $.02
Just my $.02
here's the skinny on my driving skills, the car, and the motivation behind "freshening" the motor.
1) The Driver
no i'm not the best driver in the world, but i'm not half bad either. during my drivers school at the end of the day they have a practice race to ensure you're capable of functioning in a race environment. i was down at the school with my friend who also runs a SM, and my car conked out half way through the school so i had to use his. he consistently runs mid-pack, and like myself, gets killed on the straights. during the practice race in his car i finished 3rd overall, getting passed by 2 ITS BMW's on the last lap, first in SM. at my last race when i was in my car, i got walked on down the straight by the same people i was beating at the school. i would come off the corners with more speed than the other guy (as evidenced by almost running into their bumpers), but by the end of the straight, i would be behind up to 8 car lengths. another instance i pulled out for a pass, only to have the guy pull away from me down the very same straight. given, both of these instances were against cars assembled by SM builders.
2) the car
lets be honest with ourselves. the car has 150k miles on it. i know miata's are pretty bulletproof, but even a street car should be considering a rebuild at this point. a race car on the other hand, IMO, it's almost a necessity. it's obvious that i'm making considerably less power than my competitors, which is only a minor concern. coming out of corners the car hesitates pretty badly. up near redline it dies out pretty bad whereas it seems others just keep whizzing past me. spectators tell me my shift points are about 200 yards further than my competitors. this tells me i'm pretty far handicapped.
3) motivation behind the rebuild
my main concern is the parts being worn, getting valve float, breaking a rod (if that's even possible), or some other catostrophic event that would keep me from racing for extended periods of time. preventative maintenence is the main purpose, but while i have the engine apart, if there are small tricks to increasing performance, i'm willing.
1) The Driver
2) the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord »</TD></TR><TR><TD CLASS="quote">by the end of the straight, i would be behind up to 8 car lengths. </TD></TR></TABLE>
Now you understand why people were mentioning the $5K SM motors in your previous thread. A simple rebuild is only going to maybe make up for half of those 8 car lengths you fall behind. If you want the rest, you'll have to get your motor even more up to "$pec". And getting your car up to speed on the straights is the short and easy part. The rest takes lots of seat time and a lot longer, too. Have fun racing and good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus »</TD></TR><TR><TD CLASS="quote">If your staying N/A, you done need to sleeve the motor. At the most you would need to post the block, thats about it</TD></TR></TABLE>
For the second time, these motors must remain stock spec. No sleeving. No "posting". No nothing. As long as its within spec, its legal. All parts must be OEM.
Assuming you're not going to be doing the rebuild work yourself... and if you think there's a chance that once you get it "freshened" you're still going to be unhappy with running mid-pack... it might make more financial sense to go for the full rebuild upfront. This would avoid any duplication of labor charges incurred by tearing into the engine a second time.
Then again, you sound like you have an idea what you want. IMO, I would go for the rebuild unless you can be absolutely positive of the condition of a replacement engine. It's my understanding that the salvage yards are full of used miata engines - and for very little money (by honda standards) - you just never know what you'll end up with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
For the second time, these motors must remain stock spec. No sleeving. No "posting". No nothing. As long as its within spec, its legal. All parts must be OEM.</TD></TR></TABLE>
I think I missed something. All parts have to be OEM for...what?
yes i understand how people can spend 5 grand on a 'spec' motor, but i also still think that i should be able to duplicate that in my garage given time. as has been said, the parts must be oem, so it shouldn't be any more difficult than doing a basic rebuild, you just gotta find the right part that's within 'spec.' if this is true, i should be able to do this with only the FSM as my direction. is my time worth 5 grand minus parts? i dunno. i don't have a wife or kids, what else do i have to do?
and yes, i am planing on doing this rebuild myself, for better or worse
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhitEdRift »</TD></TR><TR><TD CLASS="quote">I think I missed something. All parts have to be OEM for...what?</TD></TR></TABLE>
See his sig. He drives a spec miata. He's also made several posts about the progress of his project and getting his competition license.
Most w2w and autocross classes *require* stock engines (at least internally).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord »</TD></TR><TR><TD CLASS="quote">yes i understand how people can spend 5 grand on a 'spec' motor, but i also still think that i should be able to duplicate that in my garage given time. as has been said, the parts must be oem, so it shouldn't be any more difficult than doing a basic rebuild, you just gotta find the right part that's within 'spec.' if this is true, i should be able to do this with only the FSM as my direction. is my time worth 5 grand minus parts? i dunno. i don't have a wife or kids, what else do i have to do?</TD></TR></TABLE>
To the contrary, I don't think you can duplicate a pro-built motor unless you have bushels, baskets, and pecks of parts to chose from so that you can balance the motor w/o machining. As hinted by Kirk, unless you have an unlimited set of parts and a scale, you can't legally better a pro motor no matter how much time you take.
That said, as it has been discussed here and other places, the head is THE place to make up performance w/o going the full pro-built route. Of course, I would rather send a head out than do it myself b/c it seems much more delicate. you *could* spend some snow months working on the chassis also. Bearings, calipers and ther rest will haunt you on a car that old. In either case, it looks like you have a winter project.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hracer »</TD></TR><TR><TD CLASS="quote">
up to "$pec". </TD></TR></TABLE>
