Mini Mini update again
Old Oct 2, 2003 | 06:52 PM
D's Avatar
D
Default Mini Mini update again
B16 intake manifold modifications:
motor and tranny have been test fitted in the subframe multiple times... IM has now been chopped up a bit to hopefully clear the firewall/bulkhead. Final placement of the motor/trans should take place in a few weeks, still on schedule to have a rolling chasis by december.
manifold no longer has any of that gay ****... ie, fast idle/preheat circuit chit. is a bit lighter also.
end of the plenum will more than likly have to be cut down a bit to clear the brake MC.
need more time, money and parts. Dick Yuengling never wore clownshoes.
D
Old Oct 2, 2003 | 06:58 PM
Splat's Avatar
Collector-o-Guns and Drinker
Nice
If anyone gave two ***** about trucks on here, I'd post progress of my Scout project. Ah well.
Old Oct 2, 2003 | 07:01 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Mini Mini update again (D)
There was a pretty cool OG Mini at NOPI w/ a b16 mounted in the rear. Dumbass owner said it did 10`s. lol
Old Oct 2, 2003 | 07:04 PM
B2FiNiTY's Avatar
Very nice. Glad your still working on it and haven't given up
Old Oct 2, 2003 | 08:11 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Mini Mini update again (B2FiNiTY)
Hey fagg, you missed University Ale House tonight. You could have met your wife there
Old Oct 2, 2003 | 10:19 PM
cheezthis's Avatar
Any pictures of the motor being test fitted? I'm curious how it looks.
Old Oct 2, 2003 | 11:24 PM
sackdz's Avatar
Default Re: Mini Mini update again (cheezthis)
<u>Water</u> bottle? wtf?
Old Oct 2, 2003 | 11:27 PM
TypeR 599's Avatar
I can't wait to see the finish product. Drive it to SoCal when you're done!
Old Oct 2, 2003 | 11:29 PM
J_Edwards's Avatar
Default Re: Mini Mini update again (sackdz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote"><u>Water</u> bottle? wtf?</TD></TR></TABLE>
I was going to say the same thing...
Old Oct 3, 2003 | 05:13 AM
D's Avatar
D
sorry, can't drink at work. shrug.
Old Oct 3, 2003 | 05:16 AM
J_Edwards's Avatar
You need to take some kind of update pic of the Mini including some alcoholic beverage to make up for it now.
JON
Old Oct 3, 2003 | 05:29 AM
REDNECK TYPE-R's Avatar
Default Re: (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">Nice
If anyone gave two ***** about trucks on here, I'd post progress of my Scout project. Ah well.</TD></TR></TABLE>
POST WHATCHA GOT.
Old Oct 3, 2003 | 05:38 AM
Splat's Avatar
Default Re: (REDNECK TYPE-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDNECK TYPE-R &raquo;</TD></TR><TR><TD CLASS="quote">
POST WHATCHA GOT.</TD></TR></TABLE>
Just a little interior removal in prep for redoing the floor pans and rocker panels.
Roll bar and rear interior trim it now out. Will be hitting the rear pan with the grinder this weekend to see what's up. Hope to have all the rotten stuff cut out this month, then start welding in December.
Anyone have a welder I can borrow for a couple months?
[edit] One more. Almost got all the fur out now.
Old Oct 3, 2003 | 05:51 AM
Default Re: (Splat)
THAT DOESN'T LOOK LIKE FUN.
WHAT ARE YOU DOING TO FIX THE RUST??
ANY OUTSIDE SHOTS?
Old Oct 3, 2003 | 06:04 AM
Splat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDNECK TYPE-R &raquo;</TD></TR><TR><TD CLASS="quote">THAT DOESN'T LOOK LIKE FUN.</TD></TR></TABLE>
It's not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDNECK TYPE-R &raquo;</TD></TR><TR><TD CLASS="quote">WHAT ARE YOU DOING TO FIX THE RUST??
ANY OUTSIDE SHOTS?</TD></TR></TABLE>
A good bit of the rear pan is still structurally good, so I'm goign to grind the surface rust off and coat with POR-15 or something like that. Any good piece of metal in there is going to get treated and painted.
The bad stuff will get cut out and replaced. We'll probably build new rockers using box steel and tie them into the frame with pipe. Will have to fabricate new front body mounts, probably using some big poly bushings like you'd get in a body lift kit. New floor pans will go in (thankfully the center tunnel section is rust-free), then new seat mounts, then new seats. Coat the whole damn thing with a brush-in bedliner.
Would love to get done by December so I can keep the registration current, but that is doubtful.
I had some exterior shots hosted on my other site, but it's offline now. I'll see what I can come up with.
Old Oct 3, 2003 | 06:25 AM
D's Avatar
D
Default Re: (Splat)
so I'm goign to grind the surface rust off and coat with POR-15 or something like that. </TD></TR></TABLE>
por-15 doesn't like to stick to smooth ground surfaces. either paint directly over the rust (hence, Paint Over Rust) or sandblast it to give the metal some 'tooth'.
D
Old Oct 3, 2003 | 06:30 AM
Splat's Avatar
Default Re: (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">
D</TD></TR></TABLE>
I'm not grinding down to smooth metal, just knocking the surface flakes off. I'll try to get a pic of what's been ground so far to show you how it looks.
Do any stores actually sell POR-15, or is it all internet?
Old Oct 3, 2003 | 06:34 AM
D's Avatar
D
Default Re: (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">Do any stores actually sell POR-15, or is it all internet?</TD></TR></TABLE>
I couldn't find any local. http://www.por-15.com
Old Oct 3, 2003 | 06:48 AM
Splat's Avatar
Default Re: (D)
I couldn't find any local. http://www.por-15.com</TD></TR></TABLE>
Damn that chit's expensive
Old Oct 3, 2003 | 07:09 AM
D's Avatar
D
Default Re: (Splat)
Damn that chit's expensive </TD></TR></TABLE>
you will be amazed how far a 4 OZ. (NOT 40 oz.) can will spread. I suggest you pick up the little 6 pack, and it should cover your entire floorboard at least twice.
D
Old Oct 3, 2003 | 07:16 AM
Splat's Avatar
Default Re: (D)
D</TD></TR></TABLE>
Fuggin' a, D
I'm going to get the starter pack and play with that until I figure out the best plan of attack. Got to get a welder as soon as $ permits.
Old Oct 3, 2003 | 07:23 AM
D's Avatar
D
Default Re: (Splat)
Fuggin' a, D
back to the subject at hand... who likes the bling?
Old Oct 3, 2003 | 08:51 AM
Willard's Avatar
Default Re: (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">who likes the bling?</TD></TR></TABLE>
bling it tyght... but you need a different mini.
Old Oct 3, 2003 | 09:16 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: (Willard)
Pic would have been better if the hype r could have caught up!
itr-j's Avatar
nice nice
