reving problem.....need help
Old Oct 2, 2003 | 03:28 PM
travis_118's Avatar
Default reving problem.....need help
the other day i was driving and showing a friend of mine my nitrious. I go to use the nitriuous and i get a big backfire in my intake. I pull over to make sure everyhting is okay and my car is now reving from 1 to 3 grand by itself. There is somesort of vacuum problem, or could it be the sensor above the fuel filter??? i have checked all the vacuum lines and they're all okay but when i start my car it still revs from 1 to 3 grand..... help.
Old Oct 2, 2003 | 03:32 PM
spaceman's Avatar
Default Re: reving problem.....need help (travis_118)
sounds like maybe you blew a gasket or a seal bro..showing off isnt worth blowing a motor..be careful
Old Oct 2, 2003 | 07:13 PM
JDMHatch101's Avatar
SOUNDS LIKE YOU BLEW THE TPS.
Old Oct 2, 2003 | 07:15 PM
USDM 4G VTEC's Avatar
or u blew the idle air control valve
check for codes.... maybe that will tell u wahts meesed up
they usually jus tmake the car fluctuate from 1-2 k.....
but who knows.....
we might add ur case to the book : "amazing things that happen to hondas"
xluigix47
11
Nov 2, 2012 06:56 PM
93daintegra
Oct 23, 2008 12:38 PM
asianrepnsb
12
Mar 8, 2008 12:26 PM
ballinsk8er
Mar 20, 2007 07:00 PM
ericstambaugh07
Mar 16, 2007 02:14 AM
