When building a B20VTEC which block is better, B20B or B20Z???
If I am going to be building the bottom end with aftermarket pistons and replacing the head, is there any difference in power output between a JDM B20B and B20Z?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">No!</TD></TR></TABLE>lol
The differences are all in the cams and pistons. If these are to be discarded, there is no difference between the B and the Z.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHatchBizzle »</TD></TR><TR><TD CLASS="quote">If I am going to be building the bottom end with aftermarket pistons and replacing the head, is there any difference in power output between a JDM B20B and B20Z?</TD></TR></TABLE>
If your building it it doesnt matter what you use... the bare blocks are the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dampachi_EH3 »</TD></TR><TR><TD CLASS="quote">NO actually they are BOTH JDM... the B20B went from 96-98 and the B20Z went from 99-01</TD></TR></TABLE>
umm then they are both usdm as well...there is only a jdmb20b no jdmb20z there is a usdm b20b which i 97-98 and 99-01 is the usdm b20z
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKsnatchback »</TD></TR><TR><TD CLASS="quote">
the jdm b20b, has the same compression #'s as the usdm b20z. the reason why the us has the 20bz, is because of customers complaining for the crv's lack of power! so in 00, honda brought in the b20z motor to resolve that issue!
</TD></TR></TABLE>the jdm b20b, has the same compression #'s as the usdm b20z. the reason why the us has the 20bz, is because of customers complaining for the crv's lack of power! so in 00, honda brought in the b20z motor to resolve that issue!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">B20Z starting in 99 actually.</TD></TR></TABLE>
thankx for the correction
um people seem to get this stuff mixed up all the time
OKAY this is the way it
95.5-98 JDM B20B has P3F pistons 8.8
99-00 JDM B20B has PHK pistons 9.6
96-98 USDM B20B has P3F pistons
99-00 USDM B20Z has PHK pistons
** THIS IS FACT GUYS***
Rumors- ALL JDM MOTORS have PHK high compression pistons thats BS
Okay, this IS confermed, I just dunno what it is, its a 9.2 compression B20B that still has P3F pistons in JAPAN... I know NOTHING about this motor.. someone please inform me.
_________________________________________________
Everything below the line is just MY opinion
95.5-97 b20's have 95 stamped on them
This was the first revision
98+ have 98 cast on them
after comparing a few of the, I have come to the conclusion that the 98 stamped blocks are stronger and have a different casting method with the single sleeve design
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKsnatchback »</TD></TR><TR><TD CLASS="quote"> there is only a jdmb20b no jdmb20z </TD></TR></TABLE>
wrong, there is a jdm b20z.
all motor b20b
22
Sep 29, 2003 01:01 PM
