poll on ls/vtec and other set ups
Old Oct 2, 2003 | 02:07 PM
mr.beeks's Avatar
Default poll on ls/vtec and other set ups
we are getting a lot newbies and the same question pops up
what set up should I use?
hopefully this helps cure the cause
please vote and contribute to why you chose the set up..
Modified by big reds at 4:39 PM 10/2/2003
Old Oct 2, 2003 | 03:29 PM
threatcon13's Avatar
New User
Default Re: poll on ls/vtec and other set ups (big reds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big reds &raquo;</TD></TR><TR><TD CLASS="quote">we are getting a lot newbies and the same question pops up
what set up
</TD></TR></TABLE> I chose type R, I put a jdm type R swap into my car. I chose this because I wanted OEM reliability, don't plan on doing any FI, and wanted good hp/torque w/ few bolt ons.
Old Oct 2, 2003 | 03:30 PM
RayB's Avatar
To me it's the best project out there. No two lsvtec's are built exactly the same. It's the concept of modifying your car applied to your engine. You can put your own touch to it. It is expensive if done "right". There is also some serious power that can be made with it. I also want to say the crvtec is my second choice and that's because it's the same concept but bigger. I personally am opting for a golden eagle sleeved 85mm B18A tho'.
Old Oct 2, 2003 | 04:10 PM
HaUTSaauce's Avatar
New User
I say GSR cause i dont have enough money to go with a Type r motor and has the OEM reliability that is very important to me
Old Oct 10, 2003 | 08:27 PM
GregblkEx04's Avatar
I chose b20 vtec cause its mad torque and still cheap
Old Oct 10, 2003 | 08:50 PM
HaUTSaauce's Avatar
New User
making sure the engine is built right comes into play also. I have had a b20vtec built right and had no problems with it at all but i have seen far more of them self destruct
Old Oct 11, 2003 | 12:30 PM
pythonScott's Avatar
I chose the Type R for the same reason as Threatcon13: an R powerplant replaced my LS motor. When I researched the LSVtec it became obvious that to do it "right" and get real power out of it, I'd be in the hole just as much money as an R and I would still have a crappy rod/stroke ratio and an engine that wouldn't rev as willingly as GSR/R/B16.
In my opinion the LSVtec is a waste of money. If you want more performance from the LS get some cams and a GSR,R, or B16 tranny (I've got a good friend that installed a GSR tranny in his LS and and said that it made a much bigger difference than his Crower cams). If you want more power put your LS head on a B20 block... just make sure you've got pistons with decent compression. Of course... you could always turbo the LS too
Old Oct 11, 2003 | 04:48 PM
b18hybrid's Avatar
I say LSVTEC cause of all the B18 blocks, the LS makes the most torque. Yes LSVTEC is expensive when done the right way but they cost less that $4000 (typeR cost) to build and can produce more power than ITR motors
Old Oct 11, 2003 | 07:17 PM
Hites
Guest
Posts: n/a
ok, who are the fucktards saying an lsvtec is better than a boosted ls? heres some news: A B20 VTEC IS NOT AN LSVTEC! the only thing ls about it could be the tranny and the tranny aint makin any power. just cause you swap in a vtec head doesnt make it an lsvtec. the setup that will produce the most power out of any of the choices is the ls boost; the closest to it would be the type r. the b18b is not some super-torquey engine; for the cost of it, use common sense and just get a b18c; if you want torque get an h series. the average turbo ls setup will get you ~220hp with mild turbo lag, while the type r only has 200 hp and has to rev to the ozone layer to reach that peak hp; the turbo ls will also dominate the type r on torque.
1. ls turbo
2. type r
3. ls/vtec
thats how it is, and that how the poll should look if newbs hadnt been voting on which has the most hype.
Old Oct 12, 2003 | 12:18 AM
LSvtec03's Avatar
Default Re: poll on ls/vtec and other set ups (Hites)
there are a couple of threads around right now like this one, and too many stupid people are posting bs. after my ls vtec and helping a friend with his turbo ls, and anothers turbo gsr, i agree with this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hites &raquo;</TD></TR><TR><TD CLASS="quote">
1. ls turbo
2. type r
3. ls/vtec</TD></TR></TABLE>
Old Oct 12, 2003 | 07:42 AM
Hites
Guest
Posts: n/a
Default Re: poll on ls/vtec and other set ups (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">there are a couple of threads around right now like this one, and too many stupid people are posting bs. after my ls vtec and helping a friend with his turbo ls, and anothers turbo gsr, i agree with this
thank god another person has been hit with the sanity stick .
Old Oct 12, 2003 | 08:30 PM
jdmg2gsr's Avatar
i would choose the b17 which also is what motor i'm running......the b17 is bad ***
Old Oct 12, 2003 | 08:37 PM
AlienKrOZ's Avatar
Default Re: (jdmg2gsr)
I choose B20B Turbo
Old Oct 12, 2003 | 11:11 PM
Rob Dizzle's Avatar
Default Re: (AlienKrOZ)
this is the stupidist poll ev3r
u think someone will actually choose a $5k+ setup based upon a poll that is not specific at all?
there is no best option for everyone
make a choice depending upon your budget/power goals/mileage driven per year/what u will use your car for and whatnot
Old Oct 13, 2003 | 11:01 AM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hites &raquo;</TD></TR><TR><TD CLASS="quote">1. ls turbo</TD></TR></TABLE>
looks like the voters are listening .
Old Oct 13, 2003 | 01:18 PM
97itr86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmg2gsr &raquo;</TD></TR><TR><TD CLASS="quote">i would choose the b17 which also is what motor i'm running......the b17 is bad ***</TD></TR></TABLE>
What do you have done to it? Mine sucks *** I just like the tranny.
Old Oct 13, 2003 | 01:27 PM
stockLS's Avatar
Default Re: (97itr86)
i was gonna go ls vtec but i found that for the $ invested turbo was more beneficial
Old Oct 13, 2003 | 01:34 PM
TeamSTEALTH GSR's Avatar
Default Re: (stockLS)
2 liter GSR turbo, if i had the money
Old Oct 18, 2003 | 05:30 PM
jdmg2gsr's Avatar
complete ctr valvetrain, 3 angle valve job, port/polish, milled head (.008), aem cam gears, vafc, chipped p28 ecu, aem cai, act clutch, aasco 7.5lb flywheel......just basic **** no bottomend work yet.....i plan to turbo
Old Oct 18, 2003 | 05:58 PM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmg2gsr &raquo;</TD></TR><TR><TD CLASS="quote">complete ctr valvetrain, 3 angle valve job, port/polish, milled head (.008), aem cam gears, vafc, chipped p28 ecu, aem cai, act clutch, aasco 7.5lb flywheel......just basic **** no bottomend work yet.....i plan to turbo</TD></TR></TABLE>
wow, i dont remember that being one of the options up top .
Mr.E.G.
Welding / Fabrication
13
May 16, 2007 04:27 PM
endoloqy
May 19, 2005 05:51 AM
youngsters69
Nov 18, 2003 08:26 AM
civictypenos
Oct 9, 2003 04:40 AM
