H22a JDM
Old Oct 2, 2003 | 01:14 PM
KenRed's Avatar
Default H22a JDM
I have a question. My plan is to swap out a 1999 Honda Civic SI and put in a JDM H22a 2.2 DOHC VTEC motor in the 99 SI, and I know the car weighs about 2600lbs, but my question would be, can I swap it out and get the Engine kit with the LSD, and out run the GSX AWD eclipse?
Old Oct 2, 2003 | 01:21 PM
skunk2lude01's Avatar
I think you would out run the auto, but prolly not manual, those are very quick/ and chances of finding these completely stock are rare as well, with a few mods theres no way, but you would have a fast enough car to beat most stuff around atlanta with no prob.
Old Oct 2, 2003 | 01:25 PM
KenRed's Avatar
Default Re: (skunk2lude01)
Can the h22a JDM motor produce 400 to 500 with right tuning?
Old Oct 2, 2003 | 01:26 PM
poison's Avatar
Default Re: H22a JDM (KenRed)
If you install an H22 in your Civic, then assuming the GSX isn't boost crazy (20+ lbs), then yes you will out run him.
As for swapping in an H22, search around for H22 EK information. I also have H22 swapping information I can send out. Just PM me with your email address and I will gladly send to you.
Old Oct 2, 2003 | 02:23 PM
KenRed's Avatar
Default Re: H22a JDM (poison)
Do u have a instant messenger we can talk on? if not then what will the H22a JDM do in the 1/4 and how much hp is it to the wheels 200 or 190?
Old Oct 2, 2003 | 02:27 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KenRed &raquo;</TD></TR><TR><TD CLASS="quote">Do u have a instant messenger we can talk on? if not then what will the H22a JDM do in the 1/4 and how much hp is it to the wheels 200 or 190?</TD></TR></TABLE>
A JDM h22a will put about 170hp to the wheels, it's rated at 197hp flywheel. The LSD will help, I thought and AWD GSX is only like 15.0???
In a prelude a JDM H22a is capable of 14.6-14.8 stock I would say. In a civic it will be faster assuming you can get traction.
Old Oct 2, 2003 | 03:15 PM
KenRed's Avatar
Default Re: H22a JDM (satan_srv)
What all would I need to do for Traction?
Old Oct 2, 2003 | 03:23 PM
stRodda's Avatar
other than getting lsd, just basically get some sticky tires. or if youre at the track throw on some slicks.
Old Oct 2, 2003 | 05:04 PM
rjr162's Avatar
the ones here run 14.5's.
Why dont' you just boost the B16, or build it up? Much cheaper than doing the H22 swap into it, plus you already have a VERY well supported platform. You can use aftermarket pistons no problem in the block, and run a turbo kit at atleast 10 psi.
Old Oct 2, 2003 | 05:41 PM
KenRed's Avatar
Default Re: H22a JDM (rjr162)
I wanna run atleast 12 or less if I use the SH motor, cause I want the motor to have 400+, but I know the b16 cant handle that much power so thats why i wanna do a engine swap
Old Oct 2, 2003 | 06:07 PM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KenRed &raquo;</TD></TR><TR><TD CLASS="quote">I wanna run atleast 12 or less if I use the SH motor, cause I want the motor to have 400+, but I know the b16 cant handle that much power so thats why i wanna do a engine swap</TD></TR></TABLE>
Where on earth did you hear the b16a cannot handle high amounts of power?
You need to start doing your homework, so sit down and start taking notes.
Visit this link - http://www.importreview.com/d_turbo.html
Scroll towards the bottom, you will find a 94 b16a motor that puts out 452whp at 20psi.
You are just spending more money on doing a H series swap, plus your car won't handle as well as it will with a b16a since the H series motors sit further back in the engine compartment. If you want a 400whp engine use your b16a, stroke it to a 1.8 or 2.0, then add a turbo kit, fuel upgrades, and engine management.
It sounds to me like you just want a car to beat your buddies DSM. If you simply throw a turbo kit on your b16a with exhaust and other minor upgrades you will run 13.9-14.1's on the quarter with 22" slicks. That is enough to beat a stock gsx anyday.
Pay the forced induction forum a visit if you want to go turbo, but do a search first before posting because more then likely the topic has been covered 25 times last week
Old Oct 2, 2003 | 06:41 PM
sup000's Avatar
yea with a h22a
Old Oct 2, 2003 | 06:47 PM
Nick M's Avatar
Default Re: (sup000)
where are these people coming from?
did ClubSi close down?
PLEASE do some searching
chikin pickle
Apr 6, 2015 10:05 PM
2 Loe 4 Fat Hoes
Sep 16, 2005 08:57 PM
howardjh
Dec 30, 2004 08:50 PM
fluidaccord1
Aug 25, 2003 04:02 PM
One 38
Jan 5, 2003 09:35 PM
