3 Angle Valve job on Type-R.
Old Aug 27, 2001 | 02:43 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default 3 Angle Valve job on Type-R.
Talked to a local machine shop today and they said they can do 3 angle and 5 angle jobs on my car. They quoted $125 for the 3 angle. I was wondering what kind of gains and if this is a worth while mod. While they are at it I,m thinking of getting the Mugen head gasket to raise my comp. This shop was recommended by several people so I know it must be good. Are there any certain things to watch out for. I am weary of anyone working on the R's internals so I want to be sure that it is not that much different on a type-r. By the way the price included setting the springs, whatever that means.
Old Aug 27, 2001 | 03:08 PM
Big Phat R's Avatar
Default Re: 3 Angle Valve job on Type-R. (ActiveAero)
125 bucks? That's a little low IMO.
Read my sig.
Old Aug 27, 2001 | 04:09 PM
FAST94GSR's Avatar
New User
The factory head flows pretty good as is. around 255-260 cfm. It doesn't sound like these guys have a lot of experience working on Acura engines. Dont let just anybody do headwork. There is actually a science to doing it. Bigger isn't necessarily better. Go to someone who knows Acura heads. If you're gonna get headwork spend the money and get it done by someone reputable. Portflow is pretty reasonable and they do good work. If you want a real good head make sure its flow is verified with a flowmeter. Not too many people have them. Skunk2 in Hayward California uses that on their heads. Really good headwork isn't cheap. You do pay for what you get. The difference though is night and day with a nice ported head. Hope this wasn't too long.
Old Sep 10, 2001 | 09:22 PM
MintyDip's Avatar
Default Re: 3 Angle Valve job on Type-R. (FAST94GSR)
can someone explain a 3 or 5 angle valve job?
Old Sep 10, 2001 | 09:37 PM
slowerthanu's Avatar
New User
Default Re: 3 Angle Valve job on Type-R. (MintyDip)
A 3 or 5 angle Valve job does 0 for flow, it improves valve seating, sealing and heat transfer off of the valve to the head. What they do is remove your valves and grind your valve seats to either 3 or 5 angles and then match up your valves to your seats, This can improve leakdown. Problem is, Hondas heads seal extremely well, My car leaks down between 1 and 0%. I dont reccomend it, Hondas have a 3 angle grind from the factory anyways, justlook in your factory repair manual.
Old Sep 10, 2001 | 10:03 PM
AllMotorMadness's Avatar
Just remember you get what you pay for!!! If I was you I just get headwork done by portflow if you want something good and makes power
http://www.portflow.com
thenext
11
Apr 16, 2011 12:15 PM
fatboys_ef9
10
Jan 27, 2009 06:23 PM
sled
Nov 9, 2006 01:32 PM
stizzit
Aug 30, 2004 04:22 AM
Mr. Furious
Jun 11, 2002 12:15 PM
